Water temperature
Old Jun 3, 2004 | 03:28 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Default Water temperature
I'm going to open a new can of worms. What should the optimum water temperature be for the small-block chevy engine for daily driving, no dragstrip running? I had a '79 Vette that I had rebuilt and had it running at 190 degrees, up to 205 with the AC running. I sold it and bought a '96 and have changed out the thermostat to a 160 degree. Seems to run good at around 180-200 degrees, even when the outside temperature has been up above 90 degrees. I understand that the fan control needs to be changed using a computer, but that's another story line. I would just like to know what an optimum temperature should be, then work towards that. Comments?
Old Jun 4, 2004 | 08:32 AM
silver84's Avatar
silver84
Default Re: Water temperature (gvajgrt)
Try to keep the temp under 200 f.
Old Jun 4, 2004 | 10:06 AM
SilverBeast
St. Jude Donor '05
Default Re: Water temperature (silver84)
OK, cool. So what's the lowest temperature to keep the oil from going out to lunch?
Old Jun 10, 2004 | 10:18 PM
87NassauBlue's Avatar
87NassauBlue
This is an old can of worms actually, I run a 180 in the summer and a 195 in the winter. I won't run a 160 because of the risk of sludge buildup. I also disagree with the theory of a 160 making you engine run cooler.
Old Jun 10, 2004 | 10:20 PM
87NassauBlue
By the way, I have observed that a 160 stat will run at about the same temp as a 180 stat. The warmup is just slower, allowing sludge building moisture to remain in your crankcase longer.
Old Jun 11, 2004 | 07:22 AM
silver84's Avatar
silver84
I would be concerned if:
you frequently turned the engine off -
with the oil temp less than 180 f.
Old Jun 16, 2004 | 10:46 AM
SilverBeast
St. Jude Donor '05
OK. This looks like the end of the thread. Bottom line: keep the oil above 180 degrees and it should be OK. We only get about 90 days of temps below 70 here, and few of those days are below 40. I don't want to change the thermostat again (I just replaced the distributor!!), so will ensure that when I drive, it gets up to proper temperature. Thanks for all the comments.
To Water temperature
