100 shot dyno numbers
Old Jun 16, 2004 | 10:42 AM
Half Fast's Avatar
Half Fast
Default 100 shot dyno numbers
Finally put the car on the dyno for some numbers plus the 100 shot.
Results were 455rwhp 437 rwtq and a perfect A/F. I may be pulling a little too much timing so those numbers are a little conservative. The 100 shot comes on at 3200 and goes to 6100.
The next step is adding a 50 shot 2nd stage that comes in at 4900 and goes up to 6200 and raising my shift points to 6300 from 6200.
Not too bad on a stock short block.
Old Jun 16, 2004 | 10:57 AM
krivera's Avatar
krivera
Default Re: 100 shot dyno numbers (Half Fast)
DAMN!!!!!! Nice JOB!
Old Jun 16, 2004 | 11:40 AM
StealDads67's Avatar
StealDads67
What did it put down before the nitrous??
Those are some really strong numbers you got there!
Old Jun 16, 2004 | 11:59 AM
Half Fast's Avatar
Half Fast
Default Re: 100 shot dyno numbers (StealDads67)
N/A it's at ~360rwhp
Old Jun 18, 2004 | 03:14 PM
rjetrider's Avatar
rjetrider
I was curious on what kit you have and if it's wet or dry.
Old Jun 18, 2004 | 06:15 PM
Half Fast's Avatar
Half Fast
Default Re: 100 shot dyno numbers (rjetrider)
My sig has all of my mods. It's a NX Gemini MAF system and it's wet. I would only use a wet kit on an LT1 as I do not believe that the computer in them is quick enough to make the fuel adjustments that you can get away with on an LS1 and I do not like the method of raising the fuel pressure as it will give inconsistent results and you may damage your motor. It's a basic that N2O needs more fuel added and I prefer to tune the jetting myself.
No matter which kit you use nothing beats tuning and checking it on a dyno with wideband.
Old Jun 19, 2004 | 07:02 PM
rjetrider's Avatar
rjetrider
Just curious what were your A/F numbers off and on juice. I'm getting a lot of conflicting info on perfect A/F on nitrous. Thanks for any help.
Old Jun 23, 2004 | 01:42 PM
Half Fast's Avatar
Half Fast
12.8 NA, 11.6 with N20
Old Jun 28, 2004 | 10:46 AM
rjetrider's Avatar
rjetrider
thanks for the reply this should really help out when I start tunnig mine.
Old Jun 28, 2004 | 09:47 PM
Half Fast's Avatar
Half Fast
The 11.6 is pretty good A/F with a 100 shot. As the size of the shot goes up you want the A/F to go richer than that.
To 100 shot dyno numbers
