Underhood lights quit
Old Jun 23, 2004 | 06:01 PM
droeme's Avatar
droeme
Default Underhood lights quit
The underhood lights on my '94 suddenly quit working. Bulbs seem OK. There's no voltage at the lights. What might be the problem....where should I look?. I didn't notice a fuse for them, but may have overlooked it. By the way, my first post on t/p.
Old Jun 23, 2004 | 06:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Underhood lights quit (droeme)
On my '88 they are powered off the CTSY/CLK Fuse.
Trace the wires from the lights and make sure the connections are good.
If so, open a connector to see if there is power to the connector.
If so, check/service the mercury switches in the lights.
Old Jun 23, 2004 | 07:12 PM
ittlfly's Avatar
ittlfly
Default Re: Underhood lights quit (65Z01)
There is a fuse holder for the lights in the left front well just below the headlight. It's in a 'weather pack' case and mounted to the inner fender well just on the outboard side of the AIR pump. Check that first. Hope this helps.
[Modified by ittlfly, 4:13 PM 6/23/2004]
Old Jun 23, 2004 | 07:18 PM
XQIZT's Avatar
XQIZT
Default Re: Underhood lights quit (ittlfly)
this may sound silly...but my 85 hood lights act up sometimes....give the lenses a good solid tap with your fingers...those mercury switched can be a lil flaky...unplug the wires where ever they connect, then plug them back in...wiggle it...you may get away without having to spend any money
Old Jun 23, 2004 | 08:33 PM
MostWanted's Avatar
MostWanted
Default Re: Underhood lights quit (Orlando85UCFvette)
My lights actually ended up having the wrong bulbs which made them work "sometimes". I changed them out with the correct ones and now they are good to go!
Old Jun 23, 2004 | 08:43 PM
droeme's Avatar
droeme
Ittlfly....good call....the fuse holder is out of the little pack and the fuse is missing. When I close the circuit I have lights. Do you happen to know what size fuse I need? (now that I think about it, I had some service done about a week ago....I'll bet they took the fuse out to keep the lights off and didn't put it back.)
Old Jun 24, 2004 | 11:19 PM
ittlfly's Avatar
ittlfly
It's a red colored one..I think it ia a 5 amp. Glad you got it working.
Old Jun 25, 2004 | 11:05 AM
1996man's Avatar
1996man
ive had my underhood lights go out a couple times. once it was the fuse and the next time i thoguht it was the fuse again but it was fine. come to find out both bulbs just happened to blow at the same time!
Old Jun 25, 2004 | 02:07 PM
booya93's Avatar
booya93
Default Re: Underhood lights quit (1996man)
Probably a silly question, but doesn't the fuse for the underhood lights control something to do with the air pump? I thought I had read that somewhere. I only ask because mine are out as well..
Old Jun 25, 2004 | 06:34 PM
ittlfly's Avatar
ittlfly
Default Re: Underhood lights quit (booya93)
No. The AIR pump has a fuse in a separate 'weatherpack' holder mounted on the pump itself. (at least on the 92 its wired that way).
Old Jun 26, 2004 | 08:21 PM
mik's Avatar
mik
It's the red 10 amp fuse.
To Underhood lights quit
