spark plug in my starter??
Old Jun 24, 2004 | 01:02 AM
dannydoo's Avatar
dannydoo
Default spark plug in my starter??
what!!!!!!!!!is what i said!!
i removed my starter to change it cause it pooped out evry 7 or 8 cranks...
when i went to put the new one in it wouldnt fit....i matched them up and they were exact!!!!!!!!!talk about gettin pissed off....finally i stuck my hand in there thinkin maybe i layed a rag in there or something?? out comes a spark plug!!!
how the hell did it get there??any ideas????????????????????????????????
theres no other way exept if the heads were removed right??even that way sounds stiff??
Old Jun 24, 2004 | 02:11 AM
JAKE's Avatar
JAKE
Default Re: spark plug in my starter?? (dannydoo)
Where did you stick your hand?
Chances are that someone, in changing the plugs, dropped one and it got stuck on top of the starter. Whoever it was didn't fish it out with a magnet, and just bought another one and installed it.
Best I can come up with.
Jake
Old Jun 24, 2004 | 02:17 AM
dannydoo's Avatar
dannydoo
the plug was inside the startes cavity...next to the flywheel....it was internally droped somehow?idunno?
Old Jun 24, 2004 | 02:25 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
It almost had to be laying on top of starter and then fell in the hole when you tilted and removed the starter..The plug and your flywheel would be beat to H3LL and back.. if it were even possible for it to have been riding in there. Thats my guess anyway.
Old Jun 24, 2004 | 02:38 AM
dannydoo's Avatar
dannydoo
some how it was jammed in cause it was i beech to pull the starter out in the first place...since the starter has a pointy nose and there is about 2 inches of gap between the fly wheel and bottem of casing there is som room...thank god it wasnt dancing....if it was ,,the ceramic would be broken...what a mess that would be...there isnt a shield that comes off,,that you can see the flywheel??witout pulling the starter?maybe sabatoge?no one ever touched my car exept for alignment since ive owned it
Old Jun 24, 2004 | 02:52 AM
skateparkdave
Thats a head scratcher for sure..I'm just glad for you that it found a spot to remain imobile..that could have been a real mess
Old Jun 24, 2004 | 03:28 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Geez, And I thought this was gonna be another "Banana-in-the-Tailpipe" joke!
To spark plug in my starter??
