Exhaust valve question
Old Jun 24, 2004 | 01:43 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Exhaust valve question
What prevents the exhaust valve from opening during compression, and causes it to open after the combustion?
Old Jun 24, 2004 | 01:45 PM
vvv90's Avatar
vvv90
Default Re: Exhaust valve question (ir0nmaiden420)
Valve Spring closes Valve. Cam/lifter/rocker opens valve.
Old Jun 24, 2004 | 02:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed the valve springs hold the valves closed unless they are forced open by the rocker arms.
The cam turns at 1/2 the crank speed and the cam lobes are ground so that it (through the valve lifters) pushes up on the push rods, which rotates the rocker arms and opens the valves at the proper time during pistion travel.
This allows one camshaft to control both intake and exhaust valves during two crankshaft rotations, completing the 4-stroke cycle of our SBC engine.
To Exhaust valve question
