cleared code 32 in 91
Old Jun 24, 2004 | 10:35 PM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
Default cleared code 32 in 91
I replace the EGR valve, now The dealer says the 91 doesn't have a temp switch. I couldn't seem to find it either, so I am curious does anyone here know if they have one?
Old Jun 25, 2004 | 02:28 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: cleared code 32 in 91 (96zride)
I've heard that too but the ECM must have some form of feedback from the EGR system else it couldn't generate a code 32.
Old Jun 25, 2004 | 11:50 AM
Steel Blue 91's Avatar
Steel Blue 91
The only thing I could find (EGR related) was a vacuum/elec. switch operated by TB vac. The only place the vac tube goes is to the EGR. It sits directly under the DS of the throttle body.
Old Jun 25, 2004 | 11:54 AM
Wheelman's Avatar
Wheelman
I dont know if your 91 is the same as my 89 but the EGR temp switch on my 89 is screwed into the egr tube that is covered in head shield that goes across the passenger side valve cover towards the firewall
Old Jun 25, 2004 | 01:13 PM
da6speed's Avatar
da6speed
Default Re: cleared code 32 in 91 (Wheelman)
It is not the same because my freind has an 88' and I have a 91' and we parked our cars next to each other and compared the two and there are alot more differences on all the electrical than I would have thought seeing how they both have the tpi setup in them.
Old Jun 25, 2004 | 01:31 PM
Wheelman's Avatar
Wheelman
Default Re: cleared code 32 in 91 (da6speed)
Who woulda thunk it
Old Jun 25, 2004 | 01:49 PM
ANTI VENOM's Avatar
ANTI VENOM
It don't gots one!!! When the ecm runs a code 32 test, it looks at the fuel integrator and must detect a change to pass the test. If the integrator is at a fixed value (lean or rich) when a code 32 is run, a code 32 will set. Sooooo, it only runs the code 32 scan during certain times, and park/neutral is not one of them. If your P/N switch is not operating, then the egr solenoid will not open and that could set a code 32. If you have a free flowing exhaust, little airflow will be forced through the egr valve and that can also trigger a code 32 during cruise! Basically it looks for a change in A/F ratio when it thinks the egr valve is open. No change equals code 32. That's my .02, take it for what its worth. You can solve that problem with a quick burn of a chip.
Old Jun 25, 2004 | 03:45 PM
Nak's Avatar
Nak
7th Gear
Default Re: cleared code 32 in 91 (ANTI VENOM)
I'm under the impression that the '90-'96 engines were able to use the oxygen sensors to detect when EGR was introduced. If that's the case, maybe you should check your O2 sensors. Also, a vacuum leak can cause a Code 32, so it might simply be a disconnected hose somewhere.
Old Jun 26, 2004 | 01:28 AM
96zride's Avatar
96zride
Default Re: cleared code 32 in 91 (Nak)
Good stuff! I have headers and exhaust, they may explain alot. However today I bought a used ECM with chip, put it in car would not run!!!! Swapped chips car runs sweet! Still no fans. Now how do I know how the damn chip is programmed? I am starting to think this car is very modified(and fast)realitvily speaking for an L98
Old Jun 26, 2004 | 02:44 AM
ANTI VENOM's Avatar
ANTI VENOM
Just bring that thing down to sticksville and let Uncle Anti fix it. I don't know alot about alot of things, but I know a little about vettes. If it aint stock, I can tell you what you have and what you don't have. Peace!!!!!!
Old Jun 26, 2004 | 04:24 AM
96zride's Avatar
96zride
I am going to try, been so dang busy. Gotta figure it out tough. I am very perplexed.
To cleared code 32 in 91
