Distributor Rebuild questions?????
Old Jun 25, 2004 | 09:38 AM
korvette4u's Avatar
korvette4u
Default Distributor Rebuild questions?????
87 stock, end play tolerances? and which end(or both) to place shims?.....the gears are ok and i replaced bushings. i have a kit Moroso shims kit..
Old Jun 25, 2004 | 10:16 AM
korvette4u's Avatar
korvette4u
Default Re: Distributor Rebuild questions????? (korvette4u)
TTT
Old Jun 25, 2004 | 10:32 AM
CFI-EFI's Avatar
CFI-EFI
*I* haven't seen a spec on end play, but I set mine at .006"-.010". The shims install, easily, at the gear end.
RACE ON!!!
Old Jun 25, 2004 | 10:54 AM
korvette4u's Avatar
korvette4u
Default Re: Distributor Rebuild questions????? (CFI-EFI)
RACE ON!!!
while i have the engine apart....6ths- 10ths it is ... thanks
Old Jun 25, 2004 | 03:37 PM
korvette4u's Avatar
korvette4u
currently set at 40 ths end play ... that way too much?????
To Distributor Rebuild questions?????
