Will these headers fit?
Old Jun 25, 2004 | 08:31 PM
Lv2xlr8's Avatar
Lv2xlr8
Default Will these headers fit?
Got a question for anybody that has had experience with this. Will the Hooker super comp headers (2151's) fit Darts angle plug cylinder heads. They are the Pro-1 aluminum heads. Need to know asap so I can order them soon as posible. I cant wait to get my car back on the road. Thanks in advance.
Old Jun 25, 2004 | 08:39 PM
ZF Six's Avatar
ZF Six
Default Re: Will these headers fit? (Lv2xlr8)
As long as the degree of the heads are the same I don't see why not.
Old Jun 25, 2004 | 08:47 PM
NitrousSam's Avatar
NitrousSam
Default Re: Will these headers fit? (ZF Six)
Actually the angle of the head relates to the valve angle (23 degree and so on).
Old Jun 25, 2004 | 09:02 PM
Lv2xlr8's Avatar
Lv2xlr8
But will the angled spark plugs/wires be too close to the header?
Old Jun 26, 2004 | 03:21 PM
CFI-EFI's Avatar
CFI-EFI
If you don't know the plug angle, check with Dart. The Hooker headers are footnoted to NOT fit AFR angle plug heads. Bear in mind, that AFR has made heads with two different plug angles. The standard, "L98" angle, and AFR's own, proprietary angle. The 2151s fit the "L98" angle but not the "AFR angle". Dart should be able to tell you about the angle(s) they have made. Hooker may know, also.
RACE ON!!!
Old Jun 26, 2004 | 03:42 PM
vader86's Avatar
vader86
From what I'm hearing, the Dart Pro wont fit with the L98 angle Hookers, at least not very well. Theyre not the same angle.
Though, I guess the straight plug Darts and straight plug Hookers will.
I'm looking into the Dart Pro 200cc at the moment too.
[Modified by vader86, 4:12 PM 6/26/2004]
Old Jun 26, 2004 | 09:16 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Will these headers fit? (vader86)
There are no straight plug AND angle plug Hooker headers. The 2149s and the 2151s fit both straight and Chevrolet, angled plug heads.
Old Jun 27, 2004 | 03:52 PM
johnnyevans's Avatar
johnnyevans
The 2151 Hookers work fine with the Dart Pro 1s. My 89 has been running them for almost 2 years without a problem. A couple of the plugs are fun to change, but there is no other problem. In fact, I'm still running the same header gaskets that came with the Hookers.
I didn't get the Hookers coated, so they are crap now. Get em coated.
Old Jun 27, 2004 | 11:25 PM
Lv2xlr8's Avatar
Lv2xlr8
Hey johnnyevans You say you got the angle plug head, correct?
Please reply just to confirm. Thanks
Old Jun 28, 2004 | 12:59 AM
johnnyevans
Yep, got the Dart Pro 1 angle plug heads, 220+, 2.08I 1.60E, +.100. 1.55 dual big block valve springs 135#closed - 380#open, titanium retainers 10d locks, 1.6 CC Pro Magnums. 311cfm @ .600 and 234cfm@ .600. Great heads, I'm running a welded Holley Stealth Ram, 36# inj, 58mm TB. Cam 236-242 @ .050, .576-.596 custom CCams roller. 808 Holden SD program in the 165 ECM.
Johnny
[Modified by johnnyevans, 1:00 AM 6/28/2004]
Old Jun 28, 2004 | 08:30 AM
Lv2xlr8's Avatar
Lv2xlr8
Awsome. Thank for reply. Looks like ill be spending some money today. Hopefolly the heads will arive before the weekend so I could get some work done on the engine.
To Will these headers fit?
