Throttle body rubber gasket...
Old Jun 26, 2004 | 08:59 AM
C4's Avatar
C4
Default Throttle body rubber gasket...
Ordered a new throttle body plate with C4 logo. It came. Took off the stock plate. The gasket which was in place was a full piece rubber piece with the appropriate knockout holes. The replacement gasket which came with the new plate was a cut out gasket. I hesitated before I replaced, wondering if the old gasket provided some kind of diaphram effect. As everything was clean, I put the new gasket/plate on and figured I'd let a quick drive assist in identifying where or not I need to put the old rubber gasket back on. Car seemed to run fine. But I'm still wondering. So, anybody got experience with this and did I make a mistake?...-C4-
Old Jun 26, 2004 | 09:03 AM
STL94LT1's Avatar
STL94LT1
Default Re: Throttle body rubber gasket... (C4)
The new gasket should work just fine.
Old Jun 26, 2004 | 09:24 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Throttle body rubber gasket... (STL94LT1)
Yes, it may just not be as reusable as the rubber one.
Old Jun 26, 2004 | 05:00 PM
C4's Avatar
C4
Default Re: Throttle body rubber gasket... (Corvette Kid NC)
Thanks guys. Will monitor and advise as necessary...-C4- :flag
To Throttle body rubber gasket...
