LT1 broke down - help needed.
Old Jun 27, 2004 | 11:36 AM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default LT1 broke down - help needed.
My '94 MN6 (which, incidentally, was for sale at the time) broke down while merging onto the expressway. Normal throttle, normal conditions. I heard a loud "tick tick tick tick tick" that was synchronized with engine speed for about 30 miles previous, sounded like it was coming from the passenger side of the motor. As I was passing 30mph the car started sounding like a tractor and was much louder than before. I grounded the pins on the ALDL connector and came up with Codes 44 and 64.
Code 44 - Bank 1 (left front) heated oxygen sensor #1 Circuit (lean exhaust indicated)
Code 64 - Bank 2 (right front) heated oxygen sensor #1 circuit (lean exhaust indicated)
The car is currently in my driveway (thank god for AAA) as I did not want to race to the nearest mechanic/dealership and proceed to get fisted. I have video/sound of the exhaust, and I will try and figure out how to post it. The car sounds like absolute hell. No idiot lights, gauges appear to function normally and idle characteristics same. Did not attempt to drive.
I have basic tools/electrical equipment and limited mechanical skill. I will not be tearing down any engines. I want to know if there is a way to discern the problem without scattering engine parts across my driveway. I must start simple. What are some thoughts and opinions?
Also, who knows good mechanics in the chicagoland area?
Old Jun 27, 2004 | 12:20 PM
Chevy Guy's Avatar
Chevy Guy
Default Re: LT1 broke down - help needed. (stormy652)
I without more info and given the ticking sound, Id start by maing sure the internals are sound. What happens when you start the car now? How did the car actually die? It really could be anything given your description, hopefully its just an exhaust problem, maybe an O2 sensor popped out? Worst case, maybe some kind of internal problem. Send the video/sound to my addy and I will give it a listen.
Old Jun 27, 2004 | 02:06 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm no expert, but I think you answered your own question. I think due to the lean condition and the ticking it's the fuel injectors.
Old Jun 27, 2004 | 02:40 PM
The Example
Default Re: LT1 broke down - help needed. (Mr Mojo)
Perhaps it is the fuel injectors, but on both cylinder banks simultaneously?
Old Jun 27, 2004 | 05:06 PM
Chevy Guy's Avatar
Chevy Guy
An injector loud enough to hear while driving the car?
Old Jun 28, 2004 | 12:08 AM
jfb's Avatar
jfb
My 87 ran like crap going to work on an expressway one day like it was running on 4 cylinders and got real HOT! Called my mechanic and after work it drove ok over to his house. BAD ECM!
To LT1 broke down - help needed.
