product called 40 BELOW
Old Jun 27, 2004 | 08:00 PM
guywade's Avatar
guywade
Default product called 40 BELOW
anyone tried ,, heard of 40 below , coolant additive? 30oz $24.99 in mad
Old Jun 27, 2004 | 08:08 PM
SPEED750's Avatar
SPEED750
Default Re: product called 40 BELOW (guywade)
Check your local autoparts store. I think autozone carries it. That way you'll save on shipping charges. This stuff does work a little, but if you have a real problem with overheating it's not the cure. It's basicly a water softener.
Old Jun 27, 2004 | 08:42 PM
guywade's Avatar
guywade
Default Re: product called 40 BELOW (SPEED750)
ahhh i use redline water wetter now , its not bad! my radiator inside and out are all clean thanks for that suggestion though , i was wondering if this was better than what i was already using,
Old Jun 28, 2004 | 04:04 AM
skeet's Avatar
skeet
I used 40 Below in my 85. The radiator was like new on the inside when i added the 40 Below.About 4 or 5 months after adding the 40 Below my radiator cap was not sealing (you could hear the hiss) and when I opened it I couldn't believe what I saw. There was brown sludge almost blocking off the filler neck. It took MANY flushes to get that system almost back to new.
I have owned many types of cars and Corvettes (which are more than a car to me) and never had any problems like this with any of those cooling systems. The only reason I can see for this happening is the 40 Below. After cleaning the system and NOT using 40 Below the system stayed clean for many years more.
Old Jun 28, 2004 | 07:20 PM
wake's Avatar
wake
Default Re: product called 40 BELOW (skeet)
It's crap, stay away from it... I had to replace a radiator in my old Camaro because that stuff sludged the whole thing up...
[Modified by wake, 4:21 PM 6/28/2004]
To product called 40 BELOW
