Dyno Guru's is this normal?
Old Jun 27, 2004 | 08:03 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Dyno Guru's is this normal?
Just had my Stock LT4 Dyno'd on a mobile dyno. Had it done a year ago, also on a mobile dyno but not the same one as this year. Last year my numbers were 298.2 HP-307.2 Torque. HP and Torque curves crossed at 4950rpm. AF averaged 11.5 from 3500-6500. This year it dyno'd 285 HP-289.7 Torque. HP and Torque curves crossed at 5250rpm. AF was 12 from 3000-6500. The only thing different with the car is 4.11 gears just put in. Question is, is the difference in readings caused by the different dyno or did the gears cause the change or is it a combo of both?
[Modified by Tony.96LT4, 7:03 PM 6/27/2004]
Old Jun 27, 2004 | 08:06 PM
88Blackonblack's Avatar
88Blackonblack
Default Re: Dyno Guru's is this normal? (Tony.96LT4)
different dyno..
Tom
Old Jun 27, 2004 | 08:15 PM
vader86's Avatar
vader86
combination of both, but mostly the dyno
Old Jun 27, 2004 | 08:33 PM
chriswtx's Avatar
chriswtx
Default Re: Dyno Guru's is this normal? (vader86)
hp and tq should always cross at 5250. When they dont on a dyno graph its because the hp and tq are not scaled the same by the dyno computer. But if you look at the hp and tq seaperatly you will see that the numbers are equal at 5250.
Old Jun 27, 2004 | 09:28 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Dyno Guru's is this normal? (chriswtx)
Thanks for the replys and explanation.
Old Jun 27, 2004 | 09:53 PM
Vic'89's Avatar
Vic'89
Tony, the 4.11's will Dyno less HP than 3.07 gears.
Vic
Old Jun 27, 2004 | 10:40 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Dyno Guru's is this normal? (Vic'89)
Vic, I went from 3.45's to the 4.11's and I expected they would but not 13 HP worth. Can I "assume" that the HP and Torque numbers are correct on my dyno from last year even though the graphs aren't scaled correctly?
Old Jun 27, 2004 | 10:53 PM
chriswtx's Avatar
chriswtx
Its not that the graphs aren't scaled correctly. They just are not scaled the same for hp and tq.
Heres an example. My 93' NSX dyno on 2 different dynos.
First one, notice the scales on the left and right are different.
Not too shabby for a Normally aspirated 3.0 267rwhp/206rwtq
Second one they are the same and cross at 5250.
The hp and tq curves just cross at different points but the numbers are correct.
[Modified by chriswtx, 9:55 PM 6/27/2004]
[Modified by chriswtx, 9:56 PM 6/27/2004]
[Modified by chriswtx, 9:57 PM 6/27/2004]
Old Jun 28, 2004 | 07:29 AM
Tony.96LT4's Avatar
Tony.96LT4
OK! I got it now. Thanks for clearing that up. I didn't notice the HP and Torque were different. I was reading both off the same scale. Thanks!
Old Jun 28, 2004 | 07:53 AM
Nathan Plemons's Avatar
Nathan Plemons
The difference in A/F ratio can simply be a difference in the sensor or in weather conditions. That's why you can't just say matter of factly "every car should be tuned for 12.8:1 A/F ratio for peak power" Although a statement like that may be techincally correct, the 02 sensor on your dyno might not be 100% accurate. So you just have to fiddle with it until you find the point where your car makes peak power.
11.5:1 on one dyno can easily be the same a/f ratio as 12:1 on another dyno, so I really wouldn't worry about that. As for the horsepower lost? It's all about the gears and weather. Wanna try a neat trick, next time you're at the dyno make a pull in third gear. The graph will have the exact same shape but you'll have lower numbers clear across the board.
Old Jun 28, 2004 | 10:47 AM
LT4BUD's Avatar
LT4BUD
I know this has been
But I still don't get it.......So we are saying 4.10's are less efficient gears than 3.45.......for same motor rpm the half-shafts, wheels, & tires are turning slower so should they take up less power?????
Ok, so 1:1 is most efficient transmission performance, but again in 1st, 2nd or 3rd the entire drive line is turning a LOT slower, again sucking up less horsepower......seems like you should get higher horsepower unless a lot of heat is going into the tranny...
I am a slow learner....maybe someday I will get it????
Old Jun 28, 2004 | 03:38 PM
NeedSpeed's Avatar
NeedSpeed
Default Re: Dyno Guru's is this normal? (LT4BUD)
Different Dynos can yeild slightly different results.
Weather plays a very big role in performance.
Another big factor is what temperature was the engine before the run? You'll see more power when the engine is cooler.
Old Jun 28, 2004 | 03:56 PM
NeedSpeed's Avatar
NeedSpeed
Default Re: Dyno Guru's is this normal? (NeedSpeed)
Oh yeah,
Tire pressue can affect your results too.
Old Jun 28, 2004 | 06:36 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Dyno Guru's is this normal? (Nathan Plemons)
Nathan, I had a pull in third gear and yes it was lower 273.7 HP and 274.0 Torque. I also had a run, the first one, thrown out cause the E-brake was on. When I saw 174 HP come up on the screen my jaw dropped but then when we found the E-brake on, the guy doing the dyno got a quick lesson in Vette E-brakes.
Thanks guys.
Old Jun 29, 2004 | 10:28 AM
lead foot 85 vet's Avatar
lead foot 85 vet
so you want to dyno in the highest gear to get the highest hp numbers? 6 th gear or in my case overdrive?
Old Jun 29, 2004 | 11:47 AM
NeedSpeed's Avatar
NeedSpeed
Default Re: Dyno Guru's is this normal? (lead foot 85 vet)
You should dyno in a 1:1 gear (for 6-spd's, 4th). This will give you a truer look at the engines power by eliminating the effects of gearing.
You can do lots of things make a run look better/more power.
Old Jun 29, 2004 | 03:25 PM
VMAX451's Avatar
VMAX451
When using a lower gear, you are accelerating the mass of the entire driveline (crank, flywheel, clutch, transmission, driveshaft, halfshafts, wheels, tires. etc.) at a higher rate, which saps some horsepower, hence less power is available at the rear wheels to turn the dyno drum.
This phenomenon only affects inertial dynos such as a Dynojet, which require a drum to be accelerated. A brake dyno can measure steady state power, taking driveline inertia out of the equation. Gear friction is also a factor, but not so much as driveline inertia when you are talking about an inertial dyno.
I always wondered why no one did a dyno run in 6th gear, until someone pointed out the tire speed at redline in 6th gear . Your engine doesn't have enough power to ever hit that speed in 6th on the road, but nothing would stop it on a Dynojet.
To Dyno Guru's is this normal?
