RPM at idle
Old Jun 27, 2004 | 08:47 PM
auger58's Avatar
auger58
Default RPM at idle
Just wondering the RPMs for a 90 auto . The tach reads about 300-350 rpm when not moving ln drive is this a little low or not?
Old Jun 27, 2004 | 08:48 PM
vader86's Avatar
vader86
Default Re: RPM at idle (auger58)
Should be twice that.
Old Jun 27, 2004 | 09:03 PM
auger58's Avatar
auger58
Thanks any input on how to fix it?
Old Jun 28, 2004 | 12:07 AM
Sam Lam's Avatar
Sam Lam
I agree with Vader in that my 89 idles somewhere in the 600 to 700 range. I suggest you place a tach on the engine and see the acutual RPM. Work from this point of reference!
Old Jun 28, 2004 | 01:03 AM
vader86's Avatar
vader86
Default Re: RPM at idle (Sam Lam)
First things to check are TPS reading and cleaning of the IAC valve, but I agree also that you need to check to see what its really doing. I think it would be hard to even have the engine running at 400rpm.
Old Jun 28, 2004 | 06:42 AM
auger58's Avatar
auger58
thanks, I'll give it a try
To RPM at idle
