Wiper Clashes
Old Jun 27, 2004 | 08:48 PM
jimturner's Avatar
jimturner
3rd Gear
Default Wiper Clashes
Oops - Sorry I first posted in C5. Newby
I purchased my first Corvette, a 96 Coupe, about six months ago. Why did I wait sooo long?
However, the wiper clashes are a real problem Seems a lot of people know about it but I can't find any information to get it solved other than removing the right side wiper. I have purchased and installed all of the correct GM blades and arms to no avail. Surely GM didn't ship the car with this problem? Can someone please give me some clues here.
Thanks,
Jim
:bb
Old Jun 27, 2004 | 11:45 PM
tempest's Avatar
tempest
Default Re: Wiper Clashes (jimturner)
here's my experience. my clashing was caused by the wiper dragging/chattering on the windshield. after trying Anco and Pylon blade inserts (i only used the rubber portion, while reusing the blades and the metal insert support) i ended up with the Teflon blade inserts from NAPA. the blades still do chatter a little, but not enough to make the blades crash.
in addition i adjusted my blades' positions so they stay far apart from each other when they come back to the hood. there are adjusting nuts under the plastic grille at the base of the windshield. there should be a section that you can snap off that reveals the adjustment nuts.
the rest - i just keep my windshield and blades clean as humanly possible.
hope this helps somewhat.
Old Jun 28, 2004 | 12:08 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: Wiper Clashes (tempest)
Hey Neighbor , Im over here in Lufkin..Small world huh?? I own the skatepark over here and also own a 90 C-4.
At the base of your wiper blades where the metal part mounts to motor gear there's retainer clips, it's a small square flap of metal. You can adjust wipers by using a flathead screwdriver and prying clip out. Then you lift wiper off of gear and raise it a tad and put it back on and pop clip in.. do it on your top wiper (passenger side) and get it about an inch above the other. If this doesn't help try applying some "Rain-X" to windshield which will reduce blade drag. I hope this helps..and welcome to the forum.
Old Jun 28, 2004 | 12:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
or get one blade thats1" shorter for the pass side... stops all the clash
Old Jul 2, 2004 | 11:19 AM
jimturner's Avatar
jimturner
3rd Gear
Thanks for all of the help. All good ideas -
Jim
To Wiper Clashes
