RESONANCE
Old Jun 28, 2004 | 07:49 AM
alfonso gomez's Avatar
alfonso gomez
Default RESONANCE
My 87 Coupe was in dire need of new mufflers and rear Y-pipe. The passenger's side muffler had a big hole in it and the Y-pipe had numerous holes in it. It sounded like a muffler-less Harley. BUT NO RESONANCE!!!!!!!
I ordered from Mid America Motorworks a Dynomax
Y-pipe with balance tube and a set of Dynomax Performance Mufflers (Part Number 603-406). It was easy to install and they sound good. BUT.......the resonance is killing me. From 1600 to about 2200 rpm it is unbearable.
My car is practically stock with only a few mods: KN filter, cut lid, coolant bypass, Hypertech Thermomaster chip, TB airfoil, no cats, 3:07 rear end. It is an automatic, by the way.
What can be done to reduce this nasty resonance?
Old Jun 28, 2004 | 07:55 AM
vader86's Avatar
vader86
Default Re: RESONANCE (alfonso gomez)
You may want some Dynomat shielding for the rear compartment area, you can get a crossover pipe welded into the Y, you can add exhaust tips that go past the bumper, or you can plug up one pipe on each side when you get on the hwy.
Otherwise, youll either have to live with it (likely) or change to a different exhaust that you can stand better.
Old Jun 28, 2004 | 08:34 AM
alfonso gomez
Default Re: RESONANCE (vader86)
The Y-pipe has a crossover pipe already. Will try the insulation and plugging one pipe in each side.
Old Jun 28, 2004 | 08:58 AM
MaddMaxx's Avatar
MaddMaxx
I just tried a pair of adjustable plumber plugs from a hardware store on my magnaflows and they really helped.
Old Jun 28, 2004 | 10:43 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Convert to a Corsa. Its the only sure fire way to get rid of resonance.
Old Jun 28, 2004 | 11:23 AM
alfonso gomez
Default Re: RESONANCE (MaddMaxx)
What are adjustable plumber plugs? Never heard of them. Do you have a photo of them? Thank You.
Old Jun 28, 2004 | 07:00 PM
skybolt31's Avatar
skybolt31
Old Jun 28, 2004 | 11:55 PM
BIG JIM 54's Avatar
BIG JIM 54
I got lucky I think...
I got the muffler Eliminators and I just let the muffler shop install them. When I picked up the car, the tips stuck out about 4" past the bottom lip of the bumper. I didn't like it at first but there's no resonates at all and the look grew on me.
Also, when I put in new rear carpets, I left old carpet in and put the new over it on the flat area. Since I did the carpets first before the Eliminators, I don't know if it contributes to the cure or not.
BIG JIM
Old Jun 29, 2004 | 11:57 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: RESONANCE (BIG JIM 54)
I've heard others say that adding tips and extending them out like that will help. I intend to try it soon myself.
Old Jun 29, 2004 | 08:09 PM
jbabk's Avatar
jbabk
Do you have a brand name for the plugs you used? Doesn't the rubber melt in the plugs? Also, how did you find 3 1/2"? I have Magnaflows on my 93 and would like to kill a little resonance if I can.
[Modified by jbabk, 8:16 PM 6/30/2004]
Old Jun 29, 2004 | 10:25 PM
BowTieBlood's Avatar
BowTieBlood
With the resonator on, my Tri-Flo didn't have any exhaust Others will disagree though, my car's........... kind of out there in it's own little world.
Good luck with your search!
To RESONANCE
