Need Help--- Fuel Injectors???
Old Jun 28, 2004 | 02:06 PM
corveteer's Avatar
corveteer
Default Need Help--- Fuel Injectors???
this is an 87 Z51. i just put in 'rebuilt' injectors and i think they are leaking.
all ready had to replace one that stuck closed and then stuck open.
after engine warm up i turn on the key and pressure gauge reads 46 then after 10 minutes gauge reads 34. i believe pressure should hold better than that. do you know what pressure should read after 10 minutes???
thanks for your help
Old Jun 28, 2004 | 02:40 PM
rick lambert's Avatar
rick lambert
Default Re: Need Help--- Fuel Injectors??? (chas stark)
Try doing a search on injectors-I can't remember about the pressure, hows your fuel pump? Just a Bump so you don't get lost
Old Jun 28, 2004 | 02:46 PM
corveteer's Avatar
corveteer
Default Re: Need Help--- Fuel Injectors??? (rick lambert)
fuel pump replaced last year
also not starting so good when hot---
To Need Help--- Fuel Injectors???
