air temp sensor relocate w/o kit?
Don't waste your money, it won't buy you anything power wise.
If you insist on moving it, buy some correct gauge wire, wire connectors, a plug for the old sensor location, and a rubber grommet the sensor will fit in for the new location. Drill a hole where you want the sensor and insert the grommet. Snip the wires to the sensor connector and insert the added length of wiring from the old location to the new. Plug the old location.
This will take you 20 minutes, cost $10 or less and gain you nothing.
St. Jude Donor '03-'05-'06-'07-'08
I have the same question.
On my 93 the air temp sensor is in the coupler.
I just bought a replacement coupler and there is no provision for an air temp sensor, so I will have to move mine. Where do you move it to.
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Mine is just behind the airfilter on the pass side drilled right into the hard plastic on the side. Real easy job!
