6 speed noise
Old Jun 28, 2004 | 10:14 PM
mstanton's Avatar
mstanton
Default 6 speed noise
Looking for help from experienced C4 owners. I'm new to C4s only owning C3s in the past. I recently bought a 92 with 6 speed transmission. When shifting, particuarly at lower rpm, the transmission seems noisy. It's not really a grinding sound, but doesn't sound normal. Although I'm not sure what normal is. Any ideas? Thanks
Old Jun 28, 2004 | 10:16 PM
JF_AH_64's Avatar
JF_AH_64
Default Re: 6 speed noise (mstanton)
Its normal...nothing to worry about. It has to do with the cut of the gears, I believe that they fixed this problem in the later C4's to lessen the noise. Welcome to C4's
[Modified by JF_AH_64, 9:17 PM 6/28/2004]
Old Jun 28, 2004 | 10:17 PM
Strick's Avatar
Strick
Do you know if it had a single mass aluminum flywheel installed? If so, the "box of rocks" sound is normal.
Old Jun 28, 2004 | 10:18 PM
JF_AH_64's Avatar
JF_AH_64
Old Jun 28, 2004 | 10:22 PM
mstanton's Avatar
mstanton
Default Re: 6 speed noise (JF_AH_64)
Thanks for the replies. I feel better already.
Old Jun 28, 2004 | 10:40 PM
1989redvette's Avatar
1989redvette
be glad you didn'y have the 89 i believe its the only year with straight cut gears and mine whines like a woman ..
Old Jun 29, 2004 | 01:15 AM
Brian Blum's Avatar
Brian Blum
Default Re: 6 speed noise (1989redvette)
Nope, the had them till 94 I believe. I know until 92 cause mine has straight cut gears also. The problem is when they went to the angle cut gears in later years to stop the noise, the tranny lost some strength.
Old Jun 29, 2004 | 07:36 AM
Skippy Stone's Avatar
Skippy Stone
Default Re: 6 speed noise (Brian Blum)
I love the sound of straight cut gears. Every time someone says "what's that whinning noise", I smile and say "it's the transmission. Isn't it great - sounds just like a race car."
Old Jun 29, 2004 | 09:17 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
My '96 has a pretty noisy 6-speed. Changing the lubricant to Castrol 10W-60 helped somewhat, but I think it's just the nature of the beast. I consider it a fair trade for the robustness of the ZF.
Larry
Old Jun 29, 2004 | 10:44 AM
1989redvette
well guess i learned something... thanks for sharing .. i too love the wine its an attention getter when cruising at low speeds..
Old Jun 29, 2004 | 11:09 AM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
The ZF6 in my 77 whines as well. I have asked a number of people and they all said it is perfectly normal, for a while I was afraid the clutch wasn't disengaging/engaging properly but she shifts fine and runs like a champ
Old Jun 29, 2004 | 11:14 AM
LD85's Avatar
LD85
Default Re: 6 speed noise (Madmikeee)
Which fluid is best to use? Do you use an additive?
Old Jun 29, 2004 | 01:02 PM
Cold_B's Avatar
Cold_B
Default Re: 6 speed noise (code5coupe)
Larry
Mine is noisy, and the alum flywheel really makes it loud, especially under 2200 rpm.
To 6 speed noise
