Check engine light(my worst enemy)
Old Jun 30, 2004 | 06:11 AM
ShadowVette's Avatar
ShadowVette
Default Check engine light(my worst enemy)
My check engine light on my 84 came on today. The first time i saw it come, it came on for about 10 seconds then shut off????????. I got back home and,then i had to leave again, it came on agian this time it stayed on. could this be electrical or mechanical, like mabey a blown head gasket. god please noooo. any advice would be appreciated. Thanx
Old Jun 30, 2004 | 06:29 AM
hngacurv's Avatar
hngacurv
Default Re: Check engine light(my worst enemy) (ShadowVette)
Check engine light means a sensor is reading something out of parameters. You need to find out what code your ECM set.
Old Jun 30, 2004 | 06:41 AM
ShadowVette
Default Re: Check engine light(my worst enemy) (hngacurv)
its been dieing lately can that be fuel related. ive heard that 84s had a bad history of starvation. and how do i check the codes on it. im 18 so i dont know as much as you guys do about cars.
Old Jun 30, 2004 | 08:11 AM
Steel Blue 91's Avatar
Steel Blue 91
You need to fund out what code was set. Go here:
http://www.c4vettes.com/codes.htm
to find out how to check the codes then post back with what you find.
Old Jun 30, 2004 | 11:12 AM
CFI-EFI's Avatar
CFI-EFI
Once you check the codes and find out what they mean, you will need a DVOM in order to check the appropriate sensors. Just remember that code from a given sensor doesn't necessarilly mean the sensor is bad. You really a service manual to help trouble shoot the causes of various codes, AND drivability issues. Go here: http://www.helminc.com
RACE ON!!!
To Check engine light(my worst enemy)
