ZF noise?
Old Jun 30, 2004 | 03:04 PM
99svrcpe's Avatar
99svrcpe
Default ZF noise?
how noisy is the ZF in a 96 LT4 with a single mass flywheel and stock clutch?
anyone running this combination?
Old Jun 30, 2004 | 03:12 PM
byte_me's Avatar
byte_me
Default Re: ZF noise? (99svrcpe)
Single Mass FW??
I have a 96 ZF I swapped into my 84 (I know, its not the same) but I reused my 4+3 single mass FW and it rattles pretty good in neutral with the clutch out..I used a stock lt1\4 clutch setup as well...I also get some noise under heavy acceleration (but I think its due to my 4+3 FW being thinner then the comparable Dual Mass. According to ZFDOC, its ok to have gear chatter as it won't hurt the ZF itself...just something to get used to...it almost has a diesel sound....rattle, rattle, rattle....
Hope this helps you some!
Old Jun 30, 2004 | 03:30 PM
99svrcpe's Avatar
99svrcpe
Default Re: ZF noise? (byte_me)
Thanks....the rattles were my main concern. I think I'll have to stick with the dual mass.
Old Jun 30, 2004 | 03:34 PM
byte_me's Avatar
byte_me
Yep- If I could- I would have...it can be quite annoying...especially when someone pulls up next to and say's "Is that the engine"?? Typically I say back "No, it's the remais of the other A-Hole who asked that very same question caught up in its teeth"!
To ZF noise?
