Help. Lately my starter interrupt has been activating for no apparant reason. Usually I sit for about 5 min and it goes off and the car will start, but today it wouldn't come back at all. Anybody have any idea how to disable this thing..its a pain.
Most likely your VATS is preventing the starter to crank due to the contacts in the ign tumbler not making with the pellet. You can prove this by removing the driver side hush panel and unplugging the two end wires of the single line of connectors. These wires are the contacts that make with the pellet and are orange and brown and come out of the steering column midway. With the key in the ign, measure the resistance of the unplugged wires from the steering column. It should measure the same as the pellet. If higher than 13k ohms, you need a new tumbler. You can temporarily defeat VATS by clipping a fixed resistor (from Radio Shack) the same value as the pellet, across the wires going over to the passenger side (VATS module). Don't do this permanently because 99% of thefts are done by bashing the column and jumping the ign. If the ign tumbler is ok, then jump the clutch safety switch (gear selector sw if auto) and try a crank.
You might first try your spare key as its pellet contacts are not worn like your everyday key. After several attempts with the wrong resistance, VATS makes you wait 6 minutes before you can start the engine assuming the correct pellet resistance is detected by VATS.
Thanks jfb. This car has 137000 rounds, and I only have one set of keys. It does seem strange that if the key was the problem that it would start it even after it has reset. The tumbler makes sense, but the inconsistancy is still odd. Does each pellet have a different resistance? I really appreciate your help.
There are about 8 different pellet resistors used. The archives should turn up a list of the values that were posted about a year ago. The contacts in the ign tumbler usually get intermittent before they completely fail. This happened to me several years ago and I used the fixed resistor until I could schedule a tumbler replacement.
Mine did the same thing, measure the resistance of your key and then measure it at the connection on the steering column. On mine, the resistance was the same, but when I moved the key around, it went way up.
I stop in every now and then. Some of the time I'm flying in N318KA which is one of our instrumented test bed helicopters. It actually belongs to the Royal Australian Navy, but displays an N number so we can fly it in the USA.
Stop in some time, my office is in the terminal building. I always have time to talk Corvettes or airplane!
Thanks, I'll try to stop in soon. I'd love to see your Eagle. I haven't been around a bi-plane since A&P school back in the 60's. We had a Staggerwing Beech D17 at the school. I helped put new Irish Linen covers on the wings while I was there. We also overhauled the 450 hp R985 Pratt it had installed.
