ZF clutch problems
Old Jul 1, 2004 | 06:31 AM
jadedvette's Avatar
jadedvette
Default ZF clutch problems
While racing a hill climb last weekend, I blew the throw out bearing to little bits in my 86', 383 c.i. coupe. I did the 4+3 convertion about two years ago and never had a problem. All the parts used were new, (no remanufactured) and up till that time no problems. I was wondering what other people with the same set up are using for clutch disks (manufacture)? Has antone else had this problem?
Thanks,
Joe
Old Jul 1, 2004 | 08:27 AM
byte_me's Avatar
byte_me
Default Re: ZF clutch problems (jadedvette)
Hi-
I did the same swap several months ago on my 84...I used a standard GM LT1\4 Clutch, pressure plate and TO bearing...keeping my 4+3 FW...other then a moderate gargle sound under heavy load...I have yet to have an issue...then again- I am not throwing your HP numbers at it either!
Old Jul 1, 2004 | 08:48 AM
LD85's Avatar
LD85
Default Re: ZF clutch problems (byte_me)
Hi-
Did you change to the ZR1 Pivot Stud or use the McLeod TOB?
Old Jul 1, 2004 | 08:53 AM
LD85's Avatar
LD85
Thanks,
Joe
What was your clutch a stock clutch etc?
Old Jul 1, 2004 | 07:33 PM
jadedvette's Avatar
jadedvette
Default Re: ZF clutch problems (ld85)
The clutch disc was from TPIS, I forget what brand they use, with their pivot stud. The pressure plate and throw out bearing was a stock GM unit. I'm jumping the gun because I don't know how much damage was done. I have the trans out but the bell housing and clutch assembly is still in. I'm going on what I see through the bell housing hole (and the amount of smoke this thing made as the clutch slipped going up the hill). I have to pull the rest down, but am thinking about a 900 series RAM clutch. Has anyone used this, and how do you feel about it?
Thanks,
Joe
Old Jul 1, 2004 | 08:21 PM
byte_me's Avatar
byte_me
Hi-
Used a modified ZR1 pivot ball stud...
To ZF clutch problems
