1993 Corvette - Fluctuating Electronics
Old Jul 1, 2004 | 01:17 PM
tpayne93's Avatar
tpayne93
6th Gear
Default 1993 Corvette - Fluctuating Electronics
Currently have a 1993. Don't drive much...used mostly for shows. I've noticed that my fuel electronics fluctuate when I drive. My MPG goes up/down constantly with unusual figures. It can go from 15 to 60 then down. My miles left is the same way. All my electronics are unreliable. I can't even trust how much gas I have...or how many miles left.
I've called a Chevrolet dealership and they can't figure it out. They want to try replacing the Fuel sending unit now. Does this sound feasible to anyone???
Any ideas/recommendations would be greatly appreciated.
Terri Payne----please email responses to tpayne@valleyproteins.com
Old Jul 1, 2004 | 02:39 PM
bogus's Avatar
bogus
Default Re: 1993 Corvette - Fluctuating Electronics (tpayne93)
hm... could be the sender... they don't last forever.
Are there any codes in the CCM?
Old Jul 2, 2004 | 09:15 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
If, as you state "all my electronics are unreliable" you probably have a grounding problem in the dash somewhere. I would start there.
Old Jul 2, 2004 | 10:15 AM
tpayne93's Avatar
tpayne93
6th Gear
Default Re: 1993 Corvette - Fluctuating Electronics (bogus)
Dealership has checked codes and can't find anything.
Old Jul 2, 2004 | 10:28 AM
QuikZilver's Avatar
QuikZilver
I just had my 93 in the dealership to check the fuel gauge sending unit, since it was not working properly. I was hoping I would have had it replaced because of gas I received from Shell Oil in South Florida, but it turns out it wasn't the problem. The problem stems from the central control module. I think you may have the same problem. Good luck!
Old Jul 2, 2004 | 02:13 PM
bogus's Avatar
bogus
a bit of understanding here:
The CCM - Chassis Control Module is the main computer in the car.
The ECM - Engine Control Module is the engine controller. which makes the car run.
The ASR/ABS Computer controls the traction control and anti-lock braking systems.
There is a serial data line that runs between the ECM and the CCM, and another from the ASR/ABS computer to the CCM.
The CCM then takes these data elements and uses them to control everything and pass data between the other modules (speed, temps things like that).
It also sends data to the gauges.
If the CCM fries, things like this can happen.
What you need to do is test the CCM, not the ECM. The CCM can be tested by jumping pins A and G on the ALDL. This will present the operator with codes in an easy to read format, on the speedometer. Really neat, actually.
If you want more info on this, please, let me know. There is an entire diagnostic procedure that will allow the user to scan through codes and reset them. All using the DIC!!!
Way cool.
So cool, I am going to post something about it in C4 Tech... just need to do it... been real busy... moving and such...
Old Jul 6, 2004 | 12:17 PM
tpayne93's Avatar
tpayne93
6th Gear
Would love to have more info. on this.....Please send to tpayne@valleyproteins.com
Thanks!
Terri
Old Jul 6, 2004 | 12:48 PM
Tom Piper's Avatar
Tom Piper
Way cool.
I agree on this.
The only problem I see is: since the CCM has a digital output to drive the segments in the digital dash display and the CCM is flaky, can you rely on what the digital dash is giving you for trouble-codes?
Another alternative is to find someone that has a Vetronix Tech-1A, MasterTech, or Tech-2 scan-tool with the appropriate cartridge to test the CCM. Most GM dealers have one. http://www.vetronix.com/diagnostics/mts3100/index.html http://www.vetronix.com/diagnostics/tech2/index.html
You could also substitute a known good CCM from another vehicle -- even if the option content were not the same (the CCM is programmed for your vehicle and options, ie. C68 climate control, ASR/ABS -- it even has the VIN programmed in it), it should still drive the dash display correctly.
Tom Piper
[Modified by Tom Piper, 12:53 PM 7/6/2004]
Old Jul 6, 2004 | 08:48 PM
bogus's Avatar
bogus
Default Re: 1993 Corvette - Fluctuating Electronics (Tom Piper)
Way cool.
I agree on this.
he agrees. I am gonna blush... I am not worthy.... I am not worthy.... I am not worthy....
Tom Piper
That make's a ton of sense. No question. If the messenger is bad, how can you trust it.
Old Jul 6, 2004 | 08:49 PM
bogus's Avatar
bogus
Thanks!
Terri
I will forward something-something soon!!!
Old Jul 7, 2004 | 02:16 AM
BAM92's Avatar
BAM92
CCM= Central Control Module.
To 1993 Corvette - Fluctuating Electronics
