Need help with '90 Auto L98 ECM Programming
Old Jul 2, 2004 | 10:00 AM
Raheel's Avatar
Raheel
Default Need help with '90 Auto L98 ECM Programming
My car has 1227727 ECM in it. I have been trying to find the .ecu file for it with no luck
Also, how do I find out the Broadcast Code of my chip? There is no information on the chip itself.
Please help.
[Modified by Raheel, 5:21 PM 7/2/2004]
Old Jul 2, 2004 | 01:15 PM
Raheel's Avatar
Raheel
Default Re: Need help with '90 Auto L98 ECM Programming (Raheel)
I just read the stock .bin file and it seems to be completely corrupted. Can someone please send me a stock .bin file for L98 '90 Auto???????
Thanks in advance.
Old Jul 2, 2004 | 04:57 PM
Aaron's 87's Avatar
Aaron's 87
Time to look around in the diy-efi.org archives. Lots of bins and ecus over there. Have you read the intro to prom burning at thirdgen.org?
Old Jul 2, 2004 | 05:37 PM
Raheel's Avatar
Raheel
Default Re: Need help with '90 Auto L98 ECM Programming (Aaron's 87)
I finally learnt that 7730 and 7727 are the same ECUs and did download an .ecu file from diy-efi and was able to read the contents of my own chip correctly.
Now I have re-programmed my chip for 30 lbs injectors, the next challenge is how to change the AFR for WOT....WB O2 sensor seems to be the right way, however I am still researching what other alternatives might be out there....Any ideas?
To Need help with '90 Auto L98 ECM Programming
