Dyno Results Procharged
The car is going in next week for a final run and then hopefully it will be complete
Well here is the dyno sheet......
http://home.comcast.net/~progrmrgui/...Procharger.jpg
[Modified by LT1Vetteguy78, 5:50 PM 7/2/2004]
[Modified by LT1Vetteguy78, 5:51 PM 7/2/2004]
[Modified by LT1Vetteguy78, 6:31 PM 7/2/2004]
Oh, weren't these guys almost guaranteeing 400 rwhp?
[Modified by STL94LT1, 6:13 PM 7/2/2004]
Are you happy thus far with the results?
What were you hoping for 400 at the wheels which is 450 at the crank!
That is 100/100 increase over stock which is not bad, and yes those injectors are big enough to run FI cars.
I'll try to explain,
Even though I'm not an expert I do understand how it works. Lets start with the compression ration, I'll make it simple.
Higher the compression ration, higher the risk of detonation.
Lower the compression ration, lower the risk of detonation.
The reason their is a risk of detonation is because compressed air warms up and if the air becomes warm enough it will pre-ignite the mix of air/gas being compressed before the spark plug fires. This is call Knock or Ping, and this is part of the reason why we have a knock sensor on our cars, and this explains why diesel engines do not need a spark plug to ignite the air/gas mixture, they have VERY high CR, its like 20 to 25 to 1.
I'm sure you've heard all about this before, so I won't go into much more details.
Now, imagine having a supercharger witch will bring up your usual, example 5.7 L of air coming into the into to engine TO lets say 8 L, it only makes sense that if you have more air to compress that the air will HEAT up even more and chances of pre-ignition are even greater. This also explains a bit why Turbo charged cars have Intercoolers to cool down the air before it is compressed into the engine. "Imagine forcing already HOT air into the piston chamber and then compressing it to make it even warmer".... can you say BOOM !!!!
So there you go a simple explanation, hope it makes sense and if someone can add on, please do so.... Like I said I don't pretend being an expert.
[Modified by TheStef, 7:12 AM 7/3/2004]
But, I would also add that higher cylinder pressures are more likely to detonate too. High comp. + high boost = very high cyl pressures. The parts affected by detonation are; Pistons, usually broken ring lands but as much as holes through piston tops, and rods/bearings. The rod can be deformed from trying to push the piston up in the bore while pre-ignition tries to force it back down (before top dead center- counter rotation). This is also why pre-ignition or detonation causes such a loss in power. Its fighting the rotation of the engine internals. This is also hard on the rod ends and hard on the rod bearings too.
When a cylinder pressure is high enough, has fuel added, and is hot enough it will ignite. Thats exactly how a diesel engine operates, and why it doesnt even need spark plugs. The glow plugs are only used until the engine is up to temperature.
A couple of guys at work run boost cars (3rd Gen RX-7 TT and Mustang 4.6 TT). They are pretty knowledgable and have been trying to talk me into going to boost. They have been saying that boosted cars need more CAPABILITY on the injectors than a NA car for the same amount of HP.
We did the numbers a couple of times and they were suggesting 36lb-42lb on my motor with 8lbs of boost.
You've got a good start now. Get the tune on it and get that wideband O2 reading. Good luck!
It could be pulling timing too. Whatever is doing it can be fixed, and when it is it'll drive like a whole different car.
