AC Blower motor not working???????
Old Jul 2, 2004 | 10:21 PM
chb88's Avatar
chb88
Default AC Blower motor not working???????
Blower motor wasn't working so I did the obvious checks, Fuses, loose connections, nothing. Took the motor out and connected it directly to the battery, blower motor worked fine. Replaced it and started checking back through the wiring and low and behold I found a burnt connector on top of the AC duct. It plugs into the blower motor control module. Evidently the rubber seal boot was missing, probably since new, and one of the connections got dirty, overheated and burnt the electrical connector. Ordered a new connector and and control module from Chris at Superior and sometime next week life will be COOL again. You all may want to check yours, even if its working, you never know what you will find.
Have a happy and safe 4th you all.
