some questions on C4
the DIC. Remove the center console. It is held by 3 screws, 2 in the back, inside the console, under the carpet. the other, in a cup holder.
You should not have to remove the shifter. This should get you enough room.
The radio plate is held on with 4 screws and a couple of spring clips.
Two of the screws are down below the lighter - if I remember rightly, they are both 9/32" heads. In the AC duct there are a couple of phillips head screws.
Pull off the cover, being aware of the spring clips (center, left of the DIC).
Using the same socket, you can now remove the DIC.
A side note - the screws that hold the shifter/console cover in place may also be 9/32" screws.
hope this helps!
PS: these notes refer to my 92, I know the dash changed, but the concept should apply.
