What will spray add?, Time reduction wise?
Old Jul 4, 2004 | 03:20 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default What will spray add?, Time reduction wise?
I was just reading Joer350's thread about getting into 12s and 65Z01's formula and was wondering what spraying say 150 would do for my L98 with the little mods in my sig.?? I've been timed unofficially in the low 13's.
[Modified by skateparkdave, 2:22 AM 7/4/2004]
Old Jul 4, 2004 | 03:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: What will spray add?, Time reduction wise? (skateparkdave)
If you can hook it up 150chp gain is worth 1.5 sec off the ET.
Old Jul 4, 2004 | 08:59 AM
Pete K's Avatar
Pete K
Default Re: What will spray add?, Time reduction wise? (65Z01)
On a summer day my mild 350 went from 13.20 @ 108 to 11.70 @ 119. My 383 went from 12.40 to 10.90 @ 129. 1.5 seconds is right on the money. Took a while to figure out how to hook all that power up. You will get an easy second if you have troubles. You will like the nos. Most fun you can have with your clothes on.
Old Jul 4, 2004 | 09:28 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
General rule of thumb is 1 second +/- for every 100 HP.
Old Jul 4, 2004 | 09:59 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: What will spray add?, Time reduction wise? (Mr Mojo)
For every 100BHP, or 100RWHP?
Old Jul 4, 2004 | 10:00 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: What will spray add?, Time reduction wise? (Pete K)
Is that with a 150 shot? Also, if you ran 13.2@108, that's a LOT of mph! With that kinda mph, you shoulda been getting DECENT 12's.
Old Jul 4, 2004 | 10:02 AM
Caboboy's Avatar
Caboboy
I did a 100 shot, (along with gears) and I'm sure it's a mid 12s car now
Old Jul 4, 2004 | 10:41 AM
Pete K's Avatar
Pete K
Default Re: What will spray add?, Time reduction wise? (TIMSPEED)
Car was often in the 12's with this old motor. On a hot day I would run the engine temp a bit warmer. Ran more consistant that way.
Old Jul 4, 2004 | 11:21 AM
TIMSPEED's Avatar
TIMSPEED
so if I ran a 13.0 now, and sprayed a 150bhp nitrous kit (125rwhp), I could run 11.5's?
Old Jul 4, 2004 | 11:48 AM
Pete K's Avatar
Pete K
Absolutely. If you hook it up,hit the button before the 2 nd gear shift and nothing flies out easy to do. If you hit the botton just after the 2nd gear shift you will likely pick up 1.2 seconds and 10 mph.
Old Jul 4, 2004 | 11:50 AM
TIMSPEED's Avatar
TIMSPEED
so if I ran a 13.0 now, and sprayed a 150bhp nitrous kit (125rwhp), I could run 11.5's? Absolutely. If you hook it up,hit the button before the 2 nd gear shift and nothing flies out easy to do. If you hit the botton just after the 2nd gear shift you will likely pick up 1.2 seconds and 10 mph.
NICE! I plan to hit the switch as soon as I launch and see 3000rpm on the tach.
Old Jul 4, 2004 | 11:57 AM
korvette4u's Avatar
korvette4u
nos is an easy way to get lots of horse power, keep in mind the expense of a new motor....u should do internal mods pistons, rings for sure..BTW i have NOS TPI Part #5051 wet spray for sale.. used only once!
Old Jul 4, 2004 | 12:00 PM
Pete K's Avatar
Pete K
When you bring on the spray makes all the difference in the et. too soon and bad happens.If you are lucky you only blow off the tires and ruin the run. NOS is a love it or hate it thing. After 50 plus bottles I still love it. I am sure my opinion will change if stuff blows up. The price you pay to dance with the devil.
Old Jul 4, 2004 | 12:10 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: What will spray add?, Time reduction wise? (korvette4u)
As long as I don't spray below 3000rpm, and she gets fuel, I should be ok. If anything DOES break, it'll be the ring lands or the pistons. Either case happens, she's getting forged slugs, and ARP Studs every place possible, with GOOD Cometic head gaskets.
Old Jul 4, 2004 | 12:14 PM
Pete K's Avatar
Pete K
My motor is cast junk. I dont worry so much about blowing up the motor. More worried about the trans and drivetrain. Motor was built dirt cheap. You are right though run it rich with minimal timing and u will be ok. Probably
Old Jul 4, 2004 | 12:18 PM
TIMSPEED's Avatar
TIMSPEED
At 100-150hp levels, I don't think it's THAT extreme, now, if it were 250+ THEN I'd start worrying.
Old Jul 4, 2004 | 12:27 PM
korvette4u's Avatar
korvette4u
timspeed: you mean broken ring lands like this? this happen last week with 150shot @ 3000rpm....using mallory hyfire electronic controller with spark retarded 6deg.. i rebuilt it ...this week, 32 hours total time from tare down to rebuild
the pistons were forged. ( i think)can you tell from the marks on the inside?
[Modified by korvette4u, 10:31 AM 7/4/2004]
[Modified by korvette4u, 10:38 AM 7/4/2004]
[Modified by korvette4u, 10:42 AM 7/4/2004]
To What will spray add?, Time reduction wise?
Old Jul 4, 2004 | 12:54 PM
TIMSPEED's Avatar
TIMSPEED
That's just not right.
Old Jul 4, 2004 | 03:16 PM
skateparkdave
Wow! What a response. I asked a question and went to bed and woke up and it's turned into a nice thread You guys are great. My next question to 65Z01 was going to be is 150chp safe? And I already have an answer. But I've heard some guys say "dont do it".."too hard on motor" and others say "cheapest, easiest way to cut a second".."risk no higher than other build ups"..so I'm like "hmmmm?".. isn't that just racing though?
So do you guys think I should go with 100 to play it kind of safe or is 150 ok if not abused? I only plan to use it occasionaly. Also, we just recently got an official track near by and I'm about to go see what it's all about but I dont know jack about bracket racing and I also want to know if nos will put me into a more modified class??All I've been doing up til now has been at a bootleg old airstrip that the private property owner lets us play on..it's kind of underground..but legal.
Thanks to all
Old Jul 4, 2004 | 04:18 PM
Mr Mojo's Avatar
Mr Mojo
I am far from being an expert on nitrous, but unless you have enough juice to last the day, I wouldn't use it for bracket racing. When we race we can go as many as a dozen runs between timeshots and rounds of elimination.
Some bracket guys will have a 50 shot on board to help them catch up if they spin off the line. They use it at the top end of the track.
My buddy put a 125 shot on his 120,000 mile LS1 and has had no problems until his gauge went bad and he had more presure than indicated and he blew his supercharger right off the engine!
