Rough Idle, hotter days ..Sometimes
Old Jul 4, 2004 | 04:28 PM
Blues77's Avatar
Blues77
Default Rough Idle, hotter days ..Sometimes
Opti, plugs, and wires are newer. Itll run fine most of the time. Usually on hotter days itll act up. On start up itll be fine then 4-5 min itll start running rough with slight miss.
Edit- stock 94
Edit #2- Also recently replaced fuel pump, has new fuel filter.
[Modified by Blues77, 3:29 PM 7/4/2004]
[Modified by Blues77, 3:30 PM 7/4/2004]
Old Jul 6, 2004 | 04:22 AM
frankrizzo1's Avatar
frankrizzo1
Default Re: Rough Idle, hotter days ..Sometimes (Blues77)
my first instinct would be opti.....
as i have just replaced mine because it was acting very similar to what you are describing.....
when was yours replaced?
also...., do a basic check of your wires..., and make sure they are on tight and corrosion free....., especially the coil wire....
