Does an 89 vette have an adjustable tps?
Old Jul 5, 2004 | 01:47 PM
calebchoson's Avatar
calebchoson
Default Does an 89 vette have an adjustable tps?
Just want to know if the 89 vettes had an adjustable tps or not?
Old Jul 5, 2004 | 02:20 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: Does an 89 vette have an adjustable tps? (calebchoson)
there is a range of adjustment with that sensor
Old Jul 5, 2004 | 02:22 PM
TheStef's Avatar
TheStef
Yes, it is adjustable its the AIC that was not adjustable on later L98 engines.
There are two screws on the side of the TPS
You might want to read this post of the tech tips section,
https://www.corvetteforum.com/techti...D=55&TopicID=2
Old Jul 5, 2004 | 02:25 PM
TheStef's Avatar
TheStef
Default Re: Does an 89 vette have an adjustable tps? (TheStef)
I just read the tech tip section and I confused myself
Its says that later L98 don't have adjustable TPS, but I know mine is adjustable since I can see the two screws on the side of it to adjust it.
Can someone help ??
Old Jul 5, 2004 | 02:32 PM
JAKE's Avatar
JAKE
I believe 90 was the first year that the TPS became NON adjustable. The ECM controls the voltage.
Up through the 89 model year, the TPS should be slotted where the two screws pass through to bolt it to the TB. Loosening those screws allows the TPS to be swiveled up/down/backward and forward.
This movement changes the voltage readings.
Jake
Old Jul 5, 2004 | 03:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Does an 89 vette have an adjustable tps? (JAKE)
The TPS was adjustable on '85-'89 L98s; beginning in '90 the ECM "learned" idle and WOT voltages so the two screw holes were no longer slotted.
On all L98s the ECM uses the IAC to control idle so base idle needs to be set correctly (450 RPM) for proper operation.
[Modified by 65Z01, 3:49 PM 7/5/2004]
Old Jul 5, 2004 | 03:46 PM
PUREC4's Avatar
PUREC4
Make sure you have an Ohm meter before trying to adjust it. Has to be in range, or things get worse.
Old Jul 5, 2004 | 03:56 PM
BiZ's Avatar
BiZ
Default Re: Does an 89 vette have an adjustable tps? (PUREC4)
A multimeter/voltmeter is needed. You will be measuring Voltage not Ohms.
To Does an 89 vette have an adjustable tps?
