How much power from an 'X' Pipe?
Old Jul 6, 2004 | 01:03 AM
plainswolf's Avatar
plainswolf
Default How much power from an 'X' Pipe?
Guys how much of a power difference is there from switching from the single resonator or muffler that both exhaust pipes go into and out of, to a good 'X' pipe?
And can you actually feel the difference?
Old Jul 6, 2004 | 01:27 AM
BAM92's Avatar
BAM92
Default Re: How much power from an 'X' Pipe? (plainswolf)
I am going to guess on this one and say 7-10hp. Change the rear mufflers to a straight through design like a magna flow and yes you will feel it. It will rev a little quicker and sound so much better.
Old Jul 9, 2004 | 07:43 PM
boulderlt4's Avatar
boulderlt4
What are the benefits of an x-pipe over a resonator?
What the hell does a resonator do?
Please help!
Old Jul 9, 2004 | 10:09 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
An X pipe uses the exhaust pulses from one side to help scavenge the exhaust from the other alternately, making the flow more efficient. An H pipe does the same thing though arguably not quite as well. A resonator is designed to just tone down the exhaust note although can have other benefits, depending on design.
Old Jul 10, 2004 | 12:23 PM
boulderlt4's Avatar
boulderlt4
Thanks!!
So for a mostly stock lt4, would I get more performance benefit from a resonator or an x-pipe! I am currently running the B&B 3" with resonator!
To How much power from an 'X' Pipe?
