92LT-1 Will thermostat help???
Old Jul 6, 2004 | 04:35 PM
WYTEOUT92's Avatar
WYTEOUT92
Default 92LT-1 Will thermostat help???
My 92 LT-1 Automatic coupe has the typical over 200 degrees coolant blues- occasionally approaching 230 on hot days in traffic. I am installing a Hypertech 160 degree thermostat. The way I understand it, this will trigger my fan at 160. How much of a reduction in coolant temperature can I realistically expect?
Old Jul 6, 2004 | 04:40 PM
92corvette's Avatar
92corvette
Default Re: 92LT-1 Will thermostat help??? (92LT-1BoughtItRight)
The thermostat won't make the fans come on any sooner....did you mean a Hypertech Chip, and thermostat?
The answer is maybe. If your radiator is not clogged up with crap.
I ended up replacing my radiator with a new one in addition to a chip and thermostat before mine cooled down enough to suit me.
[Modified by 92corvette, 3:42 PM 7/6/2004]
Old Jul 6, 2004 | 04:45 PM
vader86's Avatar
vader86
Installing a lower temp thermostat will not make your fans come on sooner.
Installing a Hypercrap chip will make them come on sooner, as the fan settings are that chip's main benefit.
Installing a 160 will lower average temps, but with sufficient time on the road, they will still reach the 230's. The only permanent fix is to have a chip made to change the fan settings (or have yours reprogrammed). However, you can clean the space between condensor and radiator, flush the cooling system, and that will lower your average temps as well.
Old Jul 6, 2004 | 05:40 PM
Lone Ranger's Avatar
Lone Ranger
You line too far north to consider a 160 tstat. Stick with the OEM stock 180 tstat. Heat doesn't hurt LT1's, @ 230 both radiator fans kick on high and will rbing down the temp. Another option, that's free of charge, would be to simply turn on the air conditioner because that will activate the radiators fans, too.
Old Jul 6, 2004 | 11:10 PM
WYTEOUT92's Avatar
WYTEOUT92
Default Re: 92LT-1 Will thermostat help??? (92corvette)
No, it is actually a Hypertech 160 degree thermostat. I plan to install a chip and according to Hypertech's web site the only chip they make for my car requires the use of a 160 degree thermostat. since I am thinking my car runs too hot and I am planning on putting in a chip I thought I would do the thermostat first.
Old Jul 6, 2004 | 11:26 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
From what I understand, the #1 reason that C4s overheat is all the crap that is lodged between the radiator and air conditioner condensor. These bottom breathers act like a big vacumn cleaner and suck stuff off the road. Take the fan shroud off and you will be suprised what you find. I have heard of dead animals, K-mart bags, condoms etc. And then have your radiator and block completely flushed, check the condition of your hoses and refill with fresh 50/50 water and antifreeze.
[Modified by corvetteronw, 11:38 PM 7/6/2004]
Old Jul 6, 2004 | 11:43 PM
vader86's Avatar
vader86
The chip wont do anything for performance, its benefit is those fan settings.
The main reason it requires use of a 160 is because it bumps the timing up so far that a cold engine is needed to keep from having problems.
You'd be better off having someone here burn you a chip, much cheaper.
Old Jul 6, 2004 | 11:48 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Really all you need is a good radiator! http://www.dewitts.com check them out! I replaced mine and never have seen any thing over 210 degrees
[Modified by grapeknutz, 10:50 PM 7/6/2004]
Old Jul 7, 2004 | 12:04 AM
BowTieBlood's Avatar
BowTieBlood
Default Re: 92LT-1 Will thermostat help??? (grapeknutz)
Don't buy a Hypertech programmer or chip.... go through PCMforless.
To 92LT-1 Will thermostat help???
