I'm not sure if anyone is interested..But here is the break down of the invoice
Procharger Pcs1 $4419.04 +$60 shipping
Installation 15 hours(really took them 34 hours, but they didn't nail me for them) $1200 dollars..
Dyno Time 3.75 hours $300 dollars
Boost Gauage $59.95 Pod $29.95 Install $120
Hazardous Material $7.50
Freon $12.88
Tranny Fluid $2.25
3" 90 degree Elbow(shrug) $35.86
Spark plugs $23.84
3/4 hose connectors(shrug) $5.16
Over FLow tank(stock one was way to big) $13.92
K & N Vent Filters $53.30
Shop Supplies $7.50
O, Lets not forget our Lovely sales tax of $386.10
Total---------$6821.19
I need the 42lbs the injectors(getting them from another corvette owner hopefully) , + the computer edit i am assuming another $400 with those two added
They've already charged you 3.75 hours of dyno time and you're chart looks like that? That seems a bit excessive to me to have already spent that much time on the dyno and have your curves all jumpy like they are.
You mentioned in your previous post that they "tuned" your engine, but didnt edit the ecm program yet. The 3.75 hours only resulted in two pulls (one pre one post SC)?? Exactly how did they tune anything without the program to edit the ecm calibrations? Did they just play with the FMU? If thats all I would dispute that charge. Overall I guess it could have been worse. The bottom line is; Are you happy with it?
The car flies, i mean it really jumps off the line...My only beef is the advertised numbers by ATI compared to what i got, i feel i was mislead bigtime.... and the noise from under the hood, which like i said before, its like a rattle from the pully's or a vibration...I LOVE the high pitch whine, that noise i like....but this other noise its equivilent to a rattling muffler(lil less noise but you get the idea)and you can hear that it is coming from the "pullys"? where the procharer is attached....If someone wants to call me i will let them listen lol to it
You have to read those dyno comparisons carefully. For example, the TPIS dyno before and afters, while true, are misleading. Take their Mini Ram for example - they claim it makes like 95 more HP than the stock L98, but what they mean is where the Mini Ram peaks it is making 95 more HP over the L98 at the same RPM - but where it peaks is far beyond where the stock L98 drops off, like 5800 RPM or something. I'm not taking shots at TPIS, just citing an example.
I don't know if this is the case with your Pro Chager or not. Glad to hear it's running strong!
That rattling is the head unit and it's normal at low idle..........like it has rocks in it......after some mileage it will get less but will always be there at low rpm...if it bothers you raise your idle....the procharger whine will get less in time also.
From: The last place on earth to get cable... Sacramento
Re: Procharger invoice breakdown (LT1Vetteguy78)
Another happy spooler... and I'll bet if ya get someone to help you tune it right (3hrs is more than enough time with the right programmer and a dyno) you'll think you can fly...
