If you don't have a real serial port you want a USB-to-serial converter that actually works with Datamaster and TunerCat. The Belkin adaptor (forgot the model # now), but it has a seperate box with 3 lights and serial connector on it works perfectly. I went thru 3 until I found one that works well. I also found that I had to "Disable CCM handshake" in order to start getting the datastream with DataMaster on my XP system. Other then that works perfect.
