My 1988 convertible's oil pressure gauge is showing 80psi most of the time. Occasionally it will drop into the 60s. Methinks it is the gauge oil pressure sender. There are 2 senders, correct? One for gauge and one for ecm? Which one is the one for the gauge? Is it available aftermarket or should I get it from my friendly neighborhood dealer? Also, in looking at the location, back of engine, how do you access it to change it? Do I have to r/r distributer? Looks awful tight back there!!!!! Any advice would be appreciated. Have a great day.
One oil pressure sender. The ECM does not get oil pressure information. It is screwed into the rear of the block to the left (car's left) of the distributor. The ARE available in replacement. Any auto parts store should be able to supply one. I got to mine by removing the ww motor. That seemed like less work than the distributor.
Thanks guys. I'll look for the tan wire and check the readings. I am confused though. On rear of engine near distributer, there are what appear to be 2 senders/switches on a fitting coming out of the rear of the engine. (My mistake on ecm, I read that one of them is for fuel pump, not ecm, sorry). When I looked in the shop manual, the component location page shows 2 components back there. Oil pressure switch and oil pressure sender. One is larger than the other. I am sorry to appear obtuse, but is the sender for the gauge the larger component back there?
Thanks very much for your kind replies and help. Yes it appears easier to remove wiper moter. Thanx for the heads up.
Well I looked in the micro fiche and your're correct. The 88 used a seperate oil sender and oil switch.
My fiche is a little blurry but the part number for the sender appears to be 14078954 and sells for $22.00.
The sender should only have one wire going to it. The metal body is the ground for the sender. The oil pressure switch should have two wires going to it. The info. I gave you was for an 89 but I would think the testing of the sender with the different resistor values would be the same.
Thanks for your help guys, I picked up an oil pressure sender, non AC but a direct match for the 14078954. Before installing I remover wiper motor to access (thanks again CFI-EFI) and pulled the tan wire. With it open gauge read 80psi and grounded read 0psi. I did not have access to any resistors by the time I got around to this Friday nite. Sooooooo...I went ahead and installed the sender, and now have oil pressures on gauge other than 80. They seem high though. Hot idle is 45psi, when I get on the throttle it goes up into the 70psi range. Perhaps the gauge is flukey as well. Anyway, sorry for the long post. BTW, what are the average oil pressures for this car. My Blazer idles at around 35psi. Do vettes have high oil pressure?
I'm glad if I was a help. The resistor tests weren't necessary, as you discovered. The 0 and 80 readings proved it was the sender. Oil pressure of 45# hot and idling sounds suspiciously high. You could double check it with a known, good, mechanical gauge, but I see another sending unit in your future. You didn't use Teflon tape on the sender threads, did you?
No, no teflon tape. The sender had what appears to be paint on the threads. Seems to have sealed well, no leaks. What are the stock pressures? As I said, my Blazer 4.3 Vortec runs at about 30-35 hot idle. Could this be an indicator of a mechanical issue? I changed the oil last week using Castrol 5w30 and a K&N filter. Again, thanks for your help.
It just seems high, to me. If it is correct, great! I have a 20 year old, stock, 160,000 mile, wonder, that is raced every week. *I* don't see pressures like that, anymore.
I do not know if it is correct. It seems high to me, as well. I did not know if vettes oil pressure ran high as a rule. I'm getting the impression that my pressure is high, or the gauge or new sender is wacky. I guess I need to find a mechanical gauge and chech it. Can anyone tell me the "factory spec" for oil pressure for a 1988 L98? CFI-EFI, again, thanks very much for your help.
Regards
Charlie
I don't know the factory specs, but my 88 runs about 28-34psi when I first start it. I don't know about WOT or anything else, but that's about roughly what I get. 45psi at idle sounds high to me as well. I'll make some checks tomorrow when I take her out and I'll report back my findings.
Corky52,
I'm not concerned that your pressure is too high. I'm concerned about the accuracy and usefulness of your gauge. 88vettelover's 28#-34#, is cold pressure and seems more realistic.
Originally Posted by 88vettelover
...my 88 runs about 28-34psi when I first start it.
Your higher, hot idle pressure, especially with that thin oil, is suspect. My concern is that if the pressure ever drops to "normal" numbers your inaccurate(?) gauge may lull you into a false sense of security, where you may actually have little or no pressure. If the gauge is correct...Great!
Okay, thanks for all of the responses. To do a mechanical pressure test, what do I need? An oil pressure test kit from Snap On runs 120.00+-, or can I get a mechanical gauge from say Advance Auto and thread it in where the sender goes to observe and compare? I really do not want to go to Mr Goodwrench if I can help it. We have a new shop that supposidly specializes in hi end cars that I could call.
Thoughts, opinions?
