Couple of problems 91 L98
Old 07-09-2004, 04:08 PM
08racer
08racer's Avatar
Default Couple of problems 91 L98
First one should be easy. How do I turn off the oil change light?
Second one the car seems to getting slower and has picked up a miss. When you step on the gas it takes off like a turd and stumbles a bit. What gives?? Bad gas?
Old 07-09-2004, 04:14 PM
FlyboyZR1
FlyboyZR1's Avatar
When's the last time it had a complete tune-up w/ new fuel filter?
Old 07-09-2004, 04:20 PM
guywade
guywade's Avatar
Turn key to Run(Dont start engine)
Press ENG MET
Within 5 seconds press it again
Within 5 seconds press and hold the GAUGES button on the trip monitor.
the change oil light will flash
Hold the guages button until the change oil light stops flashing(About 10 seconds
try range button if ya don't have guages button,
Old 07-09-2004, 04:21 PM
08racer
08racer's Avatar
Don't know I've only had the car a few months. Sounds like I should try that. The car ran great up to a few days ago. So I figured something might have broke.
Old 07-09-2004, 04:22 PM
Steel Blue 91
Steel Blue 91's Avatar
If you don't know when it was done last, you need to do it. Plugs, wires, cap rotor, fuel filter, pcv.
As for the oil light, here is a tech tip on it:
https://www.corvetteforum.com/techti...=255&TopicID=2
Old 07-09-2004, 04:24 PM
guywade
guywade's Avatar
check you main cat also
65Z01
65Z01's Avatar
Cruise-In II Veteran
Check:
-fuel pressure
-put a timing light onto each spark plug wire to see if the engine miss coincides with missed flashes
-check base timing with the EST connector open
Old 07-09-2004, 05:44 PM
08racer
08racer's Avatar
Thanks Guys. I'll get on it this weekend. I'll keep you posted.
What is the base timing supposed to be set at?
Will this problem (the missing) be manginified if I run the A/C?
In Arizona we always drive with the A/C in the on and high position
To Couple of problems 91 L98
Quick Reply: Couple of problems 91 L98
