90 Digital Dash
Old Jul 10, 2004 | 01:51 PM
9tred's Avatar
9tred
Default 90 Digital Dash
Got a 90 the digital portion of the instrument speedometer,gas level,ODO etc... is backilt at night. The light flickers only in the digital display, tach, oil level water temp etc... is steady. I'm thinking maybe the bulb has developed corrosion. Is the bulb replaceable? Has anyone seen this before?
Old Sep 12, 2004 | 11:15 PM
Pappa_Bear's Avatar
Pappa_Bear
Mine does exactly the same thing you've mentioned. I've got my whole dash apart (referenced from manual) and I only had one bulb, unrelated to the LCD Display, bad. Hoping to hear from input as it drive me crazy watching it dim, then go bright.
Old Sep 12, 2004 | 11:57 PM
DANSURE1's Avatar
DANSURE1
Default My 90 got the problem
my problem is it want stay on in the daytime, on and off.
Old Sep 13, 2004 | 01:11 AM
mikey whipreck's Avatar
mikey whipreck
sorry... wrong year... ignore me
Old Sep 13, 2004 | 06:49 PM
1fast91's Avatar
1fast91
it has to do with the battery and the amount of current getting to the cluster. my TPI vette does and so does my 2001 C5. i dont know how bad yours is but i dont think theres anything you can do.
Old Sep 13, 2004 | 07:08 PM
mikey whipreck
that's what i was gonna say, but changed my mind cause I was referring to a TPI... that's interesting its the same symptons... what problems were you having with your TPI's cluster, and what did you do?
Old Sep 13, 2004 | 08:45 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Do you have a Service Manual? If so, go to Section 8A-82-xx. If not, try this, and I'll email you a scanned copy of the pertainent portion: Headlights on. Shine a bright light at the ambient light sensor opening (above the DIC). Does this effect the brightess and steadiness of the light in the digital display? If so, replace the sensor. If not, post here or email me at a1973vette@hotmail.com.
Jac
To 90 Digital Dash
