Vibration on the highway
Old Jul 11, 2004 | 04:57 PM
87 rag's Avatar
87 rag
Default Vibration on the highway
The other day I noticed a vibration that seems stronger when I'm accelerating. It only seems noticeable on the highway over 80 mph. the faster I go the stronger it gets. Didn't go over 125.
Any one have any thoughts on what this might be, or what I should check first. I thought tire balancing because I got new tires this spring but that wouldn't be less noticeable coasting and more noticeable accelerating, would it?
Old Jul 11, 2004 | 05:17 PM
vader86's Avatar
vader86
It can be improper balancing.
It can also be balljoints or some other worn suspension piece.
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm thinking maybe balance on the drive shaft or a U-joint.
Old Jul 11, 2004 | 05:24 PM
87 rag's Avatar
87 rag
I was thinking drive shaft or something on the drive line as well but wanted another oppinion.
How would suspension create this vibration?
Either way it sounds like something I should have fixed right away.
thanks
Old Jul 11, 2004 | 05:29 PM
vader86's Avatar
vader86
Highway vibration is a very common problem for C4's.
And 90% of the time, its either bad wheel/tire balancing or balljoints.
Terribly worn shocks tend to give a 'floating' feel that is like a vibration, bad bushings and poor alignment add to it and you can really feel it considering the ability of the frame to flex.
Old Jul 11, 2004 | 05:38 PM
87 rag's Avatar
87 rag
So, I should check the wheel balancing first and if this doesn't fix it I look into the drive. U-joints, drive shaft etc.
To Vibration on the highway
