also had the idea..the noise is just in the right side, and only when its warm
its most audible near the side fenders...or is it an exhaust noise caused by the cam? i have the typical cam sound left-right in the exhaust, but right side is overlayed with the noise..i have this noise for 3 years now, didnt get better nor worse...
i hope its not a bearing, but thats almost impossible...i´ve heard the sound a dead bearing makes, and its not what my vette does...
i dont think its a wrist pin, since they float nicely in the piston, and had no play in them...
also, makes a puff of smoke on start up, but ive seen this on almost any vette..ive also new valve stem seals in it, but the exhaust seals are stock style umbrella ones, they jump up and down with the valve stem
any opinions??
im a bit frustrated..did a whole engine rebuild-upgrade and cannot get rid of this noise..
From: What did the 5 fingers say to the face? SLAP!!
I have the same EXACT noise on my '86. I just started hearing it yesterday. Sounds like it's coming from somewhere in the vicinity of the #2 cylinder, but I couldn't pinpoint it with a stetoscope either. I thought maybe injectors, but this souns is a lot louder than the injector ticking before. Sounds almost like it could be valvetrain, but it didn't get any louder when I took the oil fill cap off.
Let me know if you figure it out.
Originally Posted by RED-85-Z51
Could be the compressor, bad compressor CLutch, or bearing?
Take the accessory drive belt off, and run it for just an instant to eliminate all the accersorys. Alt, Comp, pumps...everything!
Does it get faster with increased RPMS?
Mine is not coming from the front, it's coming from the head area on the passenger side. I know it's not the compressor since mine doesn't work right now
Could still be exhaust related even though you have new headers and gaskets. When things warm up they expand and then the tick gets more audible. Snug those new headers up if you haven't already. I had a symptom like you describe on my old 84 (rip) and it was a new header gasket that I hadn't snugged up after a little break in period. Just a thought.
You (flyersfan1088) may have a different prob if you've already torqued but it still cant hurt. I just noticed that Corvette90 said he had just put on new header gaskets recently and thought maybe this might help him if he hasn't already done it.
I just got my headers on last weekend. I've retorqued once(yesterday). I'll investigate further tomorrow.
im really lost on this noise, it doenst get louder, or anything, sometimes, i wish that the engine hopefully crapes out, to replace it with a quiet one...
also i dont know, what is causing the noise??
when i did the rebuild, everything was in good condition and tolerances...
