85 Corvette bogs terribly past part throttle
Old Jul 13, 2004 | 04:29 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default 85 Corvette bogs terribly past part throttle
Hey all. My 85 is completely stock. The car has decent power so long as I'm only giving it mild part throttle. Anything more aggressive, the car bogs terribly and never catches on. That is, so long as the throttle is pressed, the car feels horrible and feels as though it's running on half its cylinders. Light throttle, all is normal.
Any ideas?
Thanks in advance!
Old Jul 13, 2004 | 04:32 PM
RonRed89's Avatar
RonRed89
Originally Posted by joeveto
Any ideas?
Without knowing too much about what you've already checked on the car, I'd suspect that it could possibly be a clogged injector or fuel filter, or perhaps even a fuel pump on its last leg.
Ron
Old Jul 13, 2004 | 04:35 PM
joeveto's Avatar
joeveto
Cruise-In V Veteran
As info, I've replaced:
The EGR, EGR temp sensor, all 8 injectors, the fuel pump (Delco unit), fuel filter, spark plug wires, cap, rotor, ignition module, cam, lifters, and all the partridges in the pear tree.
Old Jul 13, 2004 | 04:43 PM
IRC's Avatar
IRC
I think I would put a meter on the TPS it sounds like it may not be giving the correct voltage for higher throttle positions.
Old Jul 13, 2004 | 05:07 PM
B387's Avatar
B387
We are having a TPS discussion on another post, you might check there for some info. I was having a bogging condition on my 87 as well and discovered that someone had set the timing without disconnecting the "whatchamacallit" (I'll have to check an old post for the exact name and send you there). Anyway my timing was retarded a bunch. I reset at 8 degrees BTDC and it was a huge improvement. You probably already checked this so its for the what its worth dept.
good luck
Old Jul 13, 2004 | 06:17 PM
vader86's Avatar
vader86
If its that bad, I would suspect a bad MAF sensor.
I take it youre getting no SES lights at all?
Old Jul 13, 2004 | 08:15 PM
joeveto's Avatar
joeveto
Cruise-In V Veteran
You are correct. I'm not getting any codes.
Old Jul 13, 2004 | 09:45 PM
BigTodd's Avatar
BigTodd
I had a hesitation problem and it turned out to be the ECM, It was only reading half of the WOT voltage from the TPS. Changed out the ECM and it fixed that problem. Don't just jump and do this, check the TPS voltage at closed and WOT should be from .54 closed, to 4.5 or better at WOT. Have a scanner looking at what the computer sees at closed and WOT and if it does not match , then consider the ECM. ECM $75 at autozone..
To 85 Corvette bogs terribly past part throttle
