Planning on replacing fuel injectors
Old Jul 15, 2004 | 05:29 PM
jabez's Avatar
jabez
Default Planning on replacing fuel injectors
Plannning on replacing fuel injectors. Looks like a tough job. Can anyone tell me how long it normally takes? Any hints or suggestions?
Old Jul 15, 2004 | 06:10 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Don't know how long but here is a link that may help...step by step for removing them... http://www.witchhunter.com/lt1injectorreplace2.htm
Old Jul 15, 2004 | 08:54 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
looks like its more of a pita on my `87
Old Jul 16, 2004 | 02:03 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
It's pretty straight forward.
Most of the time on mine was cleaning,painting,polishing stuff.
Start on Saturday morning...finish Saturday afternoon or Sunday.
Old Jul 16, 2004 | 10:15 PM
avtt94's Avatar
avtt94
I dont know if your 1992 is set up like my 1994,but mine was really easy to replace.There is only four bolts that hold your fuel rails on and after you remove them you just pull the rails out of your intake.
Old Jul 16, 2004 | 11:15 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Definately more to remove and replace... Runners, TB, Plenum, then injectors... but all in all, not too bad
Old Jul 16, 2004 | 11:39 PM
reidry's Avatar
reidry
I'm getting ready to do the same on my '85. I haven't looked into the details in my shop manual yet, but I'm assuming that I'll need (1) gasket for the throttle body and (4) for the runners. Right?
Are there other items to replace/check while I have the plenum out?
Also check my other post on my cold start issues.
Thanks,
Ryan
To Planning on replacing fuel injectors
