3.54 rear axle ratio
I was checking on my rpo codes and i would like to know what the 3.54 rear axle ratio is. Is this just the ratio on the rear end or on the transmission gears as well?
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I don't know what the RPO code is but if you've got a six-speed and nobody's tampered with it (and if they did then knowing the RPO code wouldn't do you any good anyway) then you should have 3.54s. Here's a couple links with more info:
http://www.corvetteactioncenter.com/...9/89specs.html
http://www.idavette.net/facts/89.htm
so its only the rear axle ratio and not the gears, understood. How much better is the 3.54 axle ratio than stock, is this used to be allowed higher gear ratios for mods?
Originally Posted by STL94LT1
You won't find a rpo code for 3.54 gears in a C4. They didn't come with that gear ratio.
MUSTANGKILLA (07-09-2022)
Not that it makes a big difference. But, all ZF6/D44 C4's came with 3.45 gears, not 3.54's.
How much better it is, is all going to depend on what gears you have stock. Post your rpo codes and we'll be able to tell you what you have, and some guys should be able to tell you what you'll gain as well
Hope this doesn't repost, apparently it didn't work the first time
How much it improves your performance is all going to depend on what gears you have stock. If you post your rpo codes we can tell you what you have stock, and many member will be able to tell you of their gains with the same set-ups as well
3.54 ratio came in all the ZR-1`s 90-95 , I read that there was an option that you can have the 3.54 as a performance ratio for the ZF6 equiped vettes .
When I bought my Dana 44 it came with 3.54
Location: ...tearing up the highways, one state at a time™®©
Received 2,103 Likes
Originally Posted by Z-07 freak
3.54 was used in early 6-speed production for the `89 model year.
This IS the correct answer - and as also mentioned, the Zr1's got it as well.
Late 89's w/ ZF6 got the 3.33's and then in 90, a switch to 3.45's from then on...
Enjoy
Originally Posted by Strick
My 92 came from the factory with GHO 3.54 ratio Ax. It's a 6 speed Dana 44. It's right on my build sheet and stamped on the dif housing.
Here are my rpo codes AC1,AC3,A09,AS8,BGR,B4D,CC3,C68,DL8,D4L, D98,E5Z,E9Z,FE7,FX3,JH0,G87,GH0,J55,KC4, K68,L98,ML9,MN6,NA5,NK4,OAI,UJ6,UO4,UU8, U52,VO1,V73,XAU,YAU,Z51,1AA,1A2,1SR,245, 731.
Some of these may be off by 1 letter, sorry but the pen was messing up, and I believe there was a few more.
Elite Torch Red Member
As stated above it is also stamped on the diff.
Originally Posted by calebchoson
Here are my rpo codes AC1,AC3,A09,AS8,BGR,B4D,CC3,C68,DL8,D4L, D98,E5Z,E9Z,FE7,FX3,JH0,G87,GH0,J55,KC4,K68,L98,ML9,MN6,NA5,NK4 ,OAI,UJ6,UO4,UU8,U52,VO1,V73,XAU,YAU,Z51 ,1AA,1A2,1SR,245,731.
http://www.corvetteactioncenter.com/...89/89prod.html
I'd stick with those if you got 'em
Originally Posted by BowTieBlood
I'm guessing that's GH0? According to this site,
that says 3.54 gears.
RACE ON!!!
