slow power windows
Old Jul 16, 2004 | 04:23 PM
Jinxie's Avatar
Jinxie
Default slow power windows
My power windows on both sides seem very slow to go down and even slower up. What is the cause of this? Is there something I can lubricate or is it the actual motor itself?
Thanx
Old Jul 16, 2004 | 05:52 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You need to tell us what year your Vette is. If it's an 84,85 or early 86 it's just the way they are. You can upgrade to the late 86-96 style which are superior in speed and strength. There is a thread in the "other" area at the top of this page. Click on "other" and you will get a drop down menu, go to "tech tips" and you will find a very detailed article on how to make the change over. I'm going to do my 85 this winter.
Old Jul 16, 2004 | 08:05 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
go here....
http://webpages.charter.net/khasting...windowreg.html
Old Jul 16, 2004 | 11:47 PM
Jinxie's Avatar
Jinxie
Sorry....Its a 87
Old Jul 17, 2004 | 01:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
From the above link it looks as though the '87 has the same setup as the '88. This consists of a motor which drives the window through a simple gear setup attached to a sissor which is bolted to the bottom of the window.
If you remove the inner door panel you will see the sissor. If you cannot access it to apply lube you may need to remove or move the Al panel in the lower rear of the door.
If lube doesn't cure the lazy windows and there is no indication of binding at the sissor pivot, it's likely that the motors have deteriorated over time. The thin insulating coating on the windings can deteriorate over time, causing the motor to lose power.
Old Jul 17, 2004 | 09:58 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
To slow power windows
