HSR and 90 Vette
Originally Posted by flyersfan1088
I think the reason he's making over 400hp has more to do with the fact that he has 427 cubic inches.
Originally Posted by aklim
How about this. Instead of shortening the HSR intake we raise the hood up a couple of inches like say by adding a 2.5 in Cowl induction scoop?
How do you do this right and what does it support? I'm confused
First off, the hood is a supporting member of the front. No fenders, remember? No fenders means no structure.
When the hood is closed, it crosses the 4 corners of the front frame and joins them with the a-frame bulkhead area (the latches).
If a hood is damaged in an accident, it is hard to repair, because an accident can cause invisable stress cracks. Cutting won't (for the most part).
within the hood is framed in steel. If you cut that steel, you will have to replace it somehow.
The back 2/3rds of this generation is actually a semi-monocoque frame. The body panels are stressed... to a degree.
Try this, open your hood and drive a little... the cowl shake will be stunning!
