...alternator....
Old Jul 17, 2004 | 11:24 AM
corvette1271's Avatar
corvette1271
Default ...alternator....
....my corvette has 95k on it.....how many more miles left on the alternator?....i am thinking it needs to be changed out now.........so the dealer quotes me $253.21 for a new alternator....and how long of a job is it?.....any ideas out there?
Old Jul 17, 2004 | 11:30 AM
vader86's Avatar
vader86
There is no set mileage on an alternator, they usually go around 100K though.
It shouldnt take more than about 30min to change an alternator.
The alternator itself can be gotten cheaper than 250, autozone, advance both carry it.
Old Jul 17, 2004 | 03:28 PM
John A. Marker's Avatar
John A. Marker
In Washington, try NAPA or Schucks. I picked up one for my 85 at Schucks with life time warranty. I would try NAPA first (better product) but when mine went out I was limited to Schucks. About $150 or so...couple of years ago.
Easy to replace...take neg cable off battery, remove serp. belt, uubolt bracket holding alternator and remove all wires from alternator. Reverse to install. About 20-45 minutes depending on the tools you have and past experience.
GOOD LUCK from a native Washingtonian...we don't tan...that is rust!
Old Jul 17, 2004 | 03:36 PM
Cherry6speed's Avatar
Cherry6speed
Look in the yellow pages and find any auto electric shop. They should rebuild it for around $50.00 . Any alternator you will buy @ Autozone is also rebuilt, except they are much higher. My guy rebuilt mine and even put fresh paint on it.
Old Jul 18, 2004 | 07:34 PM
wawctw's Avatar
wawctw
I just put a lifetime gty one on from Autozone. Just over a hundred dollars. It was the easiest alternator replacement I have ever done. 20 min.
Old Jul 19, 2004 | 12:57 PM
Greenvette's Avatar
Greenvette
If you need help in replacing the alternator, I would be glad to show you how to do it. I live in Marysville.
Old Jul 19, 2004 | 01:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Actually that sounds about right for a dealer job, considering dealer markup and flat rate.
I got an AC Delco for my '88 at a local shop for $130 and installed it in about 1/2 hr.
BTW, mine went at about 115k miles.
To ...alternator....
