fuel pump
Old Jul 17, 2004 | 12:14 PM
DaddyD2's Avatar
DaddyD2
Default fuel pump
if the fuel pump in a 86 is going bad what are the signs or is there a way to test and how hard is it to change
Old Jul 17, 2004 | 12:33 PM
CFI-EFI's Avatar
CFI-EFI
Check the fuel pressure, both at idle and under load. Check or replace the fuel filter if the pressure starts to drop. Fuel pump replacement is a good project for a beginning DYIer. It is a piece of cake. Make sure you replace the intake screen (sock) when (if) you do the pump.
RACE ON!!!
Old Jul 18, 2004 | 09:32 AM
DaddyD2's Avatar
DaddyD2
what kind of pressure should i be looking for and what is the process of changing the pump
Old Jul 18, 2004 | 10:54 AM
CFI-EFI's Avatar
CFI-EFI
I don't have the specs for an '86. My guess is that the fuel pressure should be in the mid 30# range. The invesment in a factory service manual, www.helminc.com will save you a lot of money in repairs.
The fuel pump gets removed from the top of gas tank through the hole left by removing the filler neck from the tank.
You didn't mention why you suspect the pump. The main thing to check, pressure wise, is if the pressure drops under load and increased demand.
RACE ON!!!
Old Jul 18, 2004 | 11:44 AM
DaddyD2's Avatar
DaddyD2
i am getting ready to change the filter but if this does not cure the problem i will change the pump do have to take the tank out of the car to get the filler neck off
Old Jul 18, 2004 | 11:56 AM
korvette4u's Avatar
korvette4u
Are these manuals on CD's?.. or are they 3000 pages of paper? does any one have the cd version?
Old Jul 18, 2004 | 11:57 AM
CFI-EFI's Avatar
CFI-EFI
NO! That is why it is such a simple job. Just remove the the 4 torx headed screws holding the hinged filler door on, remove (by prying) the rubber "spill bib" and the filler neck screws are exposed.
RACE ON!!!
To fuel pump
