Spring rate-Three letter code conversion
Old Jul 17, 2004 | 11:20 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Default Spring rate-Three letter code conversion
I'm looking for a chart that lists springs by both rate and three letter (broadcast code) label. I have seen one chart that lists spring rates by model and RPO code (very informative, my thanks to the author), but I need some help decoding the spare springs I have lying around the garage, and individual springs I see at swap meets.
Thanks,
Mike
Old Jul 17, 2004 | 11:24 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
You might have better luck posting this in the C3 section
Old Jul 17, 2004 | 11:48 PM
69427's Avatar
69427
Why is that?
Old Jul 17, 2004 | 11:52 PM
flyersfan1088
Originally Posted by 69427
Why is that?
Because your profile says you have a '69. C4 springs are completely different than C3's
Old Jul 18, 2004 | 12:07 AM
69427's Avatar
69427
Thank you for stating the obvious. But your point is what? Do I have to register with two different userid's to get information regarding my C3 or my C4? (I posted this request in the C4 forum to obtain info on parts I use on my C4.)
Old Jul 18, 2004 | 01:01 AM
flyersfan1088
I sense an attitiude. Good luck with your search.
Old Jul 18, 2004 | 01:27 AM
Wheelman's Avatar
Wheelman
Perhaps this is the link you are looking for :
C4 Suspension Data
Old Jul 18, 2004 | 01:46 AM
BAM92's Avatar
BAM92
I recently did a search on the forum on spring codes to find out what springs I had just bought. Lot of info here in the archives.
Old Jul 18, 2004 | 01:59 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
I've got the info you're looking for. Just let me know what the codes are on your springs, and I'll let you know for what year and suspension package they are for.
Old Jul 18, 2004 | 09:45 AM
frank j. moran's Avatar
frank j. moran
Z-07, maybe you can help me also, I have a front NYR and a rear HMP. I cant remember what I took them off, I think 84s. Thanks for your help. Frank
Old Jul 18, 2004 | 10:02 AM
Bluevette85's Avatar
Bluevette85
My stock suspension 85 used the NYR spring.
Old Jul 18, 2004 | 02:21 PM
69427's Avatar
69427
C4 Suspension Data
I appreciate your suggestion here. I looked at it, and it is the chart I mentioned earlier (by Mr, Hib Halverson I believe). It's very well organized and I appreciate his work here. I'm still looking for help with my original question. On the springs themselves there is a three letter code. I am trying to find either a conversion chart that will list the three letter (broadcast) code and the attending spring rate, or a chart that will show which broadcast code belongs to which RPO code (which would allow me to use Mr. Halvorson's chart).
Thanks again for your help.
Mike
Old Jul 18, 2004 | 03:04 PM
Bluevette85
The Vette parts list has the information your looking for. You'll have to go to a dealer to look at it or try ebay to see if someone is selling a cd-rom version.
Old Jul 18, 2004 | 06:43 PM
Z-07 freak's Avatar
Z-07 freak
HMP front = 51.8 rate used on 85-87 base/FE1 and 87 Z-52s.
NYR rear = 39.9 rate 85-94 base.
Old Jul 18, 2004 | 09:59 PM
Stingraynut's Avatar
Stingraynut
I'm interested in finding a chart of the 3 letter part numbers too - I'm looking for soft spring from a 94-96. (to replace the hard ones, Z52, on my 88)
The Hib Halverson chart shows various combinations of coupe/conv F and Z ratings are all different, it would be good to know what the 3 letter prefix is for the soft springs which are rated 60N/mm front and 26N/mm rear.
ZO7 Freak, can you help me out too ?
S'nut
Old Jul 18, 2004 | 10:41 PM
Z-07 freak's Avatar
Z-07 freak
Stingraynut,
26.0 rears are code RHZ
The code for the 60.0 fronts is a little tricky. I believe it will have either code HA or JA. The 60.0 front spring is the only C4 spring I can not confirm 100%.
Old Jul 19, 2004 | 10:54 PM
Stingraynut
Thanks Z-07 freak, appreciate that. Any clues as to how I can get the front spring code ? - especially useful to me here in Australia, I don't want to arrange shipping of a spring and discover it's the same or worse than my 90N/mm
S'nut
To Spring rate-Three letter code conversion
