Will not start!
Old Jul 18, 2004 | 12:02 AM
Big Mike's Avatar
Big Mike
Navigator
Default Will not start!
My 1993 LT1 will turn over,but will not start. So far I have tried to used an AutoXray to scan the codes but it says "Vehicle not responding" with the ignition key turned on. Tried the paper clip grounding pin B and get a Code 12. Grounded pin G and no codes but C12. There is no spark to the plugs. Could this be a problem with the ECM or computer PROM?
Old Jul 18, 2004 | 11:06 AM
nobodyunknown's Avatar
nobodyunknown
Theres some fuzes to check,Theres an ecm fuze mabey others.
What made the condition occure?
Check for voltage at the dist. or opti.
Old Jul 18, 2004 | 07:00 PM
Big Mike's Avatar
Big Mike
Navigator
I parked the car and about an hour later when I returned it would not run. I have checked all fuses on the passenger side fuse box and both fuse blocks around the battery. All fuses are OK. The fuel pump is working, verified with a pressure gauge. It has no spark. No trouble codes. Does anybody know where the ECM is grounded on the block?
Old Jul 19, 2004 | 03:04 AM
avtt94's Avatar
avtt94
Check your coil.
To Will not start!
