Boost Problems.
Old Jul 19, 2004 | 10:26 AM
Svante's Avatar
Svante
Default Boost Problems.
Hello.
Firt of all. I´m from Sweden so you´ll have to excuse my spelling.
I have recently started my -85 TPI c4 with P600B sc, and i have some questions. The car starts up and runs fine but when i´m driving and give it full throttle it runs real bad. The Boost gauge shows no overboost. I have about -20-25psi vacum but it stops at 0!!. What is the problem? Is the belt slipping? Even when i´m standing still and rev the engine up to about 4-5000r/pm there is no boost. I can´t find any leakage at all. The car runs bader now than it did whitout the sc installed.
I have installed the msd 6al inside the cupé ( passanger side ) if it does any difference?
Following parts are installed.
383 eagle stroke fully balaced and arp-bolted.
ported and modifed heads 76cc
comp cams full rocker roller package and comp cams blower cam.
msd 6al with 3-step module.
ported intake.
lucas 38# injectors.
Aeromotive A1000 fuel pump.
8,7:1 cr.
Procharger P600B sc
Front mounted intercooler.
Turbo xs bov.
Manual transmission.
etc.
greatful for some useful information.
/Svante.
Old Jul 19, 2004 | 11:18 AM
swiss made's Avatar
swiss made
2nd Gear
Your charger might be to small and does not deliver enough air to feed the 383.
Old Jul 19, 2004 | 11:26 AM
Svante's Avatar
Svante
Ok.. But it sounds like a really small chance?
/Svante.
Old Jul 19, 2004 | 02:21 PM
lead foot 85 vet's Avatar
lead foot 85 vet
check your surge valve , maybe its not closing...you should be able to get it to close by rev ing the engine..I know I can on mine
Old Jul 19, 2004 | 03:35 PM
rjetrider's Avatar
rjetrider
I don't know if this is your case but my friend had a similar problem on his Z06 and it was the belt slipping. ATI helped him staighten out the problem but it took thicker pulleys and belt to get it to work.
Old Jul 20, 2004 | 11:09 AM
vvv90's Avatar
vvv90
You won't EVER see boost by sitting and reving the car. The surge valve closes under vacuum. aka driving under load.
Are you actually driving this car or just sitting still and reving it?
Old Jul 20, 2004 | 11:12 AM
TONYDEE64's Avatar
TONYDEE64
Are you actually driving this car or just sitting still and reving it? :skep
Old Jul 20, 2004 | 01:54 PM
lead foot 85 vet
The surge closes under BOOST or lack of vacuum....it's spring loaded. and like vvv90 says you'll never see vacuum reving the engine.
Old Jul 20, 2004 | 05:31 PM
Svante's Avatar
Svante
Yes i am driving the car when i´m checking the boost gauge.
More testing today. I have moved the hose from the boost gauge to the throttle body, where the hose to the "how do you say? Valvelid? originaly is inserted."
Dunno if this is a good place to mount it but it shows about 2-3psi when i´m at 2-2500r/pm with ~5% of the throttle open. But when i give it full throttle i loose all the pressure. The same if i´m reving the engine.
I´ve also installed a new belt, an extra belt tensioner and i also have used belt spray to give it more traction. The belt is very stretch now and i can hardly twist it. I´m beginning to wonder if the Sc is broken.
The a/f meter shows one dot into the rich area.
Btw. What do you mean with the surge valve? Where is that located? Don´t understand all the words =)
Old Jul 20, 2004 | 05:46 PM
Light84vette's Avatar
Light84vette
What if you disconnect the supercharger output and put your hand over it and then revv the engine in park. Its not a turbo so it should flow more air as rpms increase.
Old Jul 20, 2004 | 05:56 PM
Ice-Vette's Avatar
Ice-Vette
Cruising
Surge valve is the same as BOV.
Do you have the standard pulleys ?
I bet that is the problem.
There is no way a stock 5-7psi setup can feed a healhty 383.
Old Jul 20, 2004 | 06:17 PM
Svante's Avatar
Svante
The pulley setup on the sc is supposed to give me 14-15psi@~6000-6400r/pm´s. Said the guy i bought it from.
But why do i loose the pressure when i floor the pedal?
Old Jul 20, 2004 | 07:49 PM
Ice-Vette's Avatar
Ice-Vette
Cruising
What are the pulleys sizes ?
Or pulley ratio.
I have ratio of 2.235 with 383 and 12psi of boost.
Old Jul 20, 2004 | 10:12 PM
Brand-X's Avatar
Brand-X
Or pulley ratio.
Look for an blower inlet side restriction...could be you're collapsing one of your rubber couplings/elbows.
Old Jul 21, 2004 | 03:32 AM
Svante's Avatar
Svante
I have the standard pulley on the crank, dunno the size there without looking it up. The pulley on the sc i about5-6cm/dia. I will look it up for you tonight when i´m in the garage.
blower inlet side restriction? You mean the air filter? I´m using Bmc twin kone airfilter.
But i dont understand why the boost drops when i´m giving it full throttle. The Bov blows when i´m closing the throttle. But it doesn´t make any bigger noise.
Can it be anything mecanical problem with the engine that is causing the problems? The engine sounds good and doesn´t make any bad noises..
/Svante.
Old Jul 21, 2004 | 07:34 AM
Brand-X's Avatar
Brand-X
I had a 90 degree rubber elbow that would collapse above ~4500 rpm and would cause to the car to fall on its face...like it was dying.
On my LTx based engine, my car would fall apart when I would go into boost and then it would run bad for several days...turned out to be a bad check valve to the optispark. Under boost it was blowing intake charge into distributor. I capped the opti and haven't had a problem since.
Old Jul 21, 2004 | 12:31 PM
RonnieW's Avatar
RonnieW
Where are you measuring the boost. Do you have the boost gauge connected to the throttlebody as you indicate above?
Old Jul 21, 2004 | 01:18 PM
Svante's Avatar
Svante
Yes i have. I have tested to measure the boost on the back of the plenum and at the throttle body. I don´t have any outlet on the pressurepipe from the sc to the intake :/
/Svante.
Old Jul 26, 2004 | 06:01 AM
Svante's Avatar
Svante
The, pulley on the Sc are 61mm and the pulley on the crank is the standard pulley on the -85. Dunno the size yet though..
To Boost Problems.
