Tips for removing crank pully, balancer...
Old Jul 19, 2004 | 03:04 PM
XTwinTurbo's Avatar
XTwinTurbo
Default Tips for removing crank pully, balancer...
I did a search and wasn't able to find much info, I remember reading a step by step but that may be lost in the old forum.
Anyone have any tips for removing the crank pully / hub assembly? I need to swap my Vette's pulley to put on supercharger drive one and want to ask questions before I strip down the Vette.
Thanks for any pointers.
Old Jul 19, 2004 | 10:26 PM
pablocruise's Avatar
pablocruise
On my L98, I had the C-beam and drive line out and tilted the engine back a tad. This so, I could get the socket/extension thru the hump of the power steering fluid line.
Don't know about LT motors tho.
TTT for you.
Old Jul 19, 2004 | 10:30 PM
white94vette's Avatar
white94vette
Default Oh No, Hope you dont have a LT1
Not sure how tight your fit is, but on my 94LT1, it was a bear to get that pulley out. I was able to get the bolts out, but the pulley seemed stuck to the crank. I used some penetrating oil and let it soak in for a day then tried to tap it free...no luck. In the end, I had to weld up a special pully puller since the once from the store were too deep. I finally did get it out, and have no idea why it stuck so well.....it was only very lightly rusty.
Good Luck
To Tips for removing crank pully, balancer...
